new audiobanh what box
Old Mar 1, 2007 | 02:06 PM
themurrell's Avatar
Default new audiobanh what box
i got a AW 1206T and i was wondering what box to use or how many cubic feet to use because ill probley make a box let me know thanks
its the 12" Flame Q sub with 1100 watts rms
Old Mar 1, 2007 | 03:31 PM
B18C_EJ8's Avatar
Did your new flamer sub not come with a spec sheet?
Are you not capable of going to Audiobahn's website to get the information you seek?
http://www.audiobahn.com/Audio....html
Old Mar 1, 2007 | 03:40 PM
EBP_SI's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Did your new flamer sub not come with a spec sheet?
proof that people who buy audiobahn are a little slow.
Old Mar 1, 2007 | 03:47 PM
B18C_EJ8's Avatar
But its the Flamer Q sub with 1100 watts!
Old Mar 1, 2007 | 05:30 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">But its the Flamer Q sub with 1100 watts! </TD></TR></TABLE>
well i guess its a nice feature that it comes with the watts already
Old Mar 1, 2007 | 05:36 PM
B18C_EJ8's Avatar
That was funny...
Old Mar 2, 2007 | 09:39 AM
themurrell's Avatar
well it says 3 cubic feet for ported so i better get started making that
Old Mar 2, 2007 | 11:10 AM
fcm's Avatar
fcm
Old Fart
Default Re: (themurrell)
Well it actually gives you 3 option, 1.3cuft, 2.3cuft and 3.2cuft and an 0.5cuft-1.25cuft min/max sealed box recommendation. 94
Old Mar 3, 2007 | 11:59 AM
themurrell's Avatar
Default Re: new audiobanh what box (themurrell)
what would be bettter sealed or ported
Old Mar 3, 2007 | 02:29 PM
fcm's Avatar
fcm
Old Fart
Kind of depends on what kind of sub bass you are looking for.
Do you want tight, clean and accurate sub bass, or the kind the shakes the rear view mirrors on the car 2 lanes over?
Tight, clean and accurate is easy, sealed box.
The kind the the guy 2 lanes over can hear is harder and more expensive, vented/ported box. 94
Old Mar 3, 2007 | 09:25 PM
themurrell's Avatar
Default Re: new audiobanh what box (fcm)
thats a tough one. i like the clean sound but showing off is always nice
Old Mar 3, 2007 | 11:41 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
You better go ported bass head,
Old Mar 6, 2007 | 09:55 PM
themurrell's Avatar
with a 800 watt rms at 2 oms. should i run a cap. and what size if i do
Old Mar 7, 2007 | 09:49 AM
fcm's Avatar
fcm
Old Fart
What is the make and model of the amp? 94
Old Mar 7, 2007 | 08:44 PM
themurrell's Avatar
MA Audio M1889I
Old Mar 7, 2007 | 09:37 PM
themurrell's Avatar
400 at 4 ohms and 800 at 2 ohms
Old Mar 8, 2007 | 03:49 PM
fcm's Avatar
fcm
Old Fart
Your going to use an 800W amp to drive an 1100W sub?
Be careful with the amp gain, that sub will suck the life out of that amp, or you will just burn the subs VCs to a crisp. 94
Old Mar 8, 2007 | 08:32 PM
themurrell's Avatar
well i though you just need to be with in the 2/3 range
will then ill get a new amp in a month or so
should i get a 1100? or more?
Old Mar 9, 2007 | 05:54 AM
fcm's Avatar
fcm
Old Fart
You could run it with a 100W amp and it would work, however when "underpowered" you must be careful not to over-drive the amp into constant clipping, it is not the lack of power that damages the speaker, it's driving the amp into constant clipping that will burn the VCs.
So just be aware that if you try and get the full performance out of the sub, which you can't with the underpowered amp, you will damage the sub.
When you get a new amp, get a 1200W RMS into 2 ohms, "it's better to be over-powered then underpowered" 94
Old Mar 12, 2007 | 08:47 PM
themurrell's Avatar
my rpms go down really low like 300 is that bad? haha
how can i fix it a cap?
Worldsport
Audio / Security / Video
May 10, 2008 08:41 PM
AlienKrOZ
May 29, 2007 06:37 PM
romoracing
Apr 16, 2006 12:58 PM
zumiez007
12
Dec 2, 2004 01:14 PM
honda95civic
Jul 24, 2004 07:09 AM
