A few issues with my CIVIC
Well the first thing that is wrong is my SRS light is on and i have tryed unpluging the Battery and the light remained on. WHAT DO I DO?
The next thing is that i need a fuse panel diagram so i know what fuses are for what.
Also i have a gauge pillar and the gauges work but the gauges dont work now. they stoped workin when i was driving down the road I need to know what is wrong the gauges on the pillar are Water Temp, Air Fuel Ratio, and Nitrous
Please post your suggestions thanks for all of your thoughts
what would make the SRS Light turn on because i drove my car home from school and the next day i started my car and my SRS light just stayed on. WHAT WOULD ME THE LIGHT DO THIS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicB18C »</TD></TR><TR><TD CLASS="quote">what would make the SRS Light turn on because i drove my car home from school and the next day i started my car and my SRS light just stayed on. WHAT WOULD ME THE LIGHT DO THIS</TD></TR></TABLE>
airbag if im correct...
well i know that but what with the airbag i havent hit anything. Could it turn on as a dummy so that i go get my car serviced because there are so many miles on it or not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicB18C »</TD></TR><TR><TD CLASS="quote">well i know that but what with the airbag i havent hit anything. Could it turn on as a dummy so that i go get my car serviced because there are so many miles on it or not</TD></TR></TABLE>
the airbag doesnt have to be deployed for the srs light to be on, as for the dummy question im not to sure but that could be true...
Your SRS module could be going bad or one of the airbags could be going bad theres also whats called a clock spring in the steering colomn that can go defective, maybe one of these got disconnected, or a wire got pinched. Anything like that will set off the light and it will stay on till fixed, and when you disconnect the battery it wont forget it. Try leaving the battery disconnected for a 1/2 hour.
As far as your gauges go if they also stopped working...where do you have them running through? The reason I ask is because if the srs and gauges both started screwing up at the same time there may be an area where the wire is getting pinched/cut/shorted ETC. OTher than that though, do any other gauges not work in your car...and by that I mean stock gauges? I'm assuming you have the aftermarket gauges hooked into the fuse box for the power...check the fuses you have them tapped into...are any blown?
idk where the wires are ran because i bought the car with them in and i now they r tapped in the the fuse box so which fuse is the SRS on because it might b pluged into there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx »</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/zerothread?id=264288
SRS light reset </TD></TR></TABLE>
check out that thread...
also does anyone now why my heat seting and defrost settings dont light up they work but they dont light up but my rear defrost does which is at the top of the dash next to my hazzard and that lights up when my lights are on. could it be that the bulb is bad behind the dash or what or is it a loose wire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicB18C »</TD></TR><TR><TD CLASS="quote">also does anyone now why my heat seting and defrost settings dont light up they work but they dont light up but my rear defrost does which is at the top of the dash next to my hazzard and that lights up when my lights are on. could it be that the bulb is bad behind the dash or what or is it a loose wire </TD></TR></TABLE>
Could be the bulb, could be the wiring, could be a fuse. The fuse is the easiest thing to check, so do that first, if thats not it check the bulbs, and if that still doesn't work then use a multimeter and check the wiring.
shawnlee250
Honda Civic (2001 - 2005)
10
Jan 11, 2012 12:39 AM
undercoversi
10
Oct 4, 2004 11:18 AM
smiley02190
Apr 15, 2002 12:39 PM
