fuel lines, etc. grrrrr!!!!
Old Feb 28, 2007 | 10:32 PM
taking-back-sunday07's Avatar
Default fuel lines, etc. grrrrr!!!!
I am looking to outfit my car with steel braided hoses and plumbing here soon but the thing is..I dont understand AN sizes! I'm not sure what size of fittings to get for anything...Could someone help me understand how AN sizes compare to standard/metric sized fittings? Any help would be appreciated
Old Mar 1, 2007 | 12:46 PM
Default Re: fuel lines, etc. grrrrr!!!! (taking-back-sunday07)
BUMP
Old Mar 1, 2007 | 02:08 PM
Mikey3000's Avatar
AN fittings work in 16ths of an inch. so a -8 AN fitting would be 1/2 inch in diameter. -10 would be 5/8 inch etc. i don't believe the threads are the same as UNC, UNF or metric threads though. a common size for fuel feed hose is -8 or -10 and -6 for return hose. so when you buy that hose, you need matching AN fittings for the hose size. so if you use -10 feed hose, you use all -10 fittings.
Old Mar 1, 2007 | 02:44 PM
Default Re: fuel lines, etc. grrrrr!!!! (Mikey3000)
yay! someone finally responds! Thanks alot
LudeyKrus
Mar 12, 2019 01:19 PM
94eg5squadMD
Sep 22, 2015 05:53 AM
Charlie Moua
Dec 17, 2010 12:27 AM
kwah
Nov 16, 2010 08:55 PM
Bond
Feb 16, 2010 11:25 AM
