Idle, Overheating, Heater Problem (Searched)
Old Feb 28, 2007 | 10:02 PM
dividedas1's Avatar
Default Idle, Overheating, Heater Problem (Searched)
Today I was driving my car to work and i noticed that at idle it almost sounded like i had a vacuum leak. Then I get about halfway to work and i notice that my temperature gauge is alot higher then normal and it is also fluctuating alot. The third thing i realized was that my heater was not blowing hot air only cold air. brrr
95 Civic DX - good old stock d15b7
I did some research and ive been told the fluctuating idle and temp problems might be either a temperature sensor failure or low coolant. I also searched Honda-tech and came up with a possible blown headgasket but i havent noticed any smoke or anything like that recently.
Before i go and try to fix what ever might be wrong with my car i just wanted to see what the general opinion of the people on Honda-tech was
Old Feb 28, 2007 | 11:43 PM
dividedas1's Avatar
bed time bump
Old Mar 1, 2007 | 12:04 AM
JDM_Frijoles's Avatar
Default Re: (dividedas1)
I'm putting money on the headgasket but it could also be that you have a faulty thermostat, timing/idle - check your distributor, or your out of coolant. Just my.02
Old Mar 1, 2007 | 03:42 AM
Burton7706's Avatar
Default Re: (JDM_Frijoles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles &raquo;</TD></TR><TR><TD CLASS="quote">I'm putting money on the headgasket but it could also be that you have a faulty thermostat, timing/idle - check your distributor, or your out of coolant. Just my.02 </TD></TR></TABLE>
I agree. I had the same problem. When you first start your car take off the radi cap and look for constant bubbles. If there are bubbles it is a bad HG.
Old Mar 1, 2007 | 06:32 AM
choppedndropped's Avatar
Default Re: (Burton7706)
Yea when you first start it and the motor is cold! Most people know this but if you take the radiator cap off when the motors hot you can get burned. I think it would be the termostat if theres no sign of headgasket damage.
Old Mar 1, 2007 | 09:57 AM
dividedas1's Avatar
Default Re: (choppedndropped)
thanks for the info. Would a blown HG cause the heat not too work in my car as well. My heater was blowing nice hot air untill all of this happened recently
Old Mar 1, 2007 | 10:43 AM
Well if your thermostat goes out i know that it can make your heat not work at all sometimes. but also when your heater core goes out it does the same. I'm not sure but since the heater core is involved with the over all cooling system you might want to research the symtoms of a bad heater core.
Old Mar 1, 2007 | 05:42 PM
dividedas1's Avatar
thank you everyone. Honda-tech alway points me in the right direction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles &raquo;</TD></TR><TR><TD CLASS="quote">or your out of coolant</TD></TR></TABLE>
my lower radiator hose had a small tear in it and i had not noticed antifreeze puddles cause its so damn wet out here. Replaced the hose gave it new coolant and it fixed every single one of the issues (rough idle after warm up, no heat and my wacky temp. gauge)
thanks
e30FTMFW
Nov 18, 2008 11:52 AM
BlueLude84
Sep 18, 2008 09:30 AM
entityzero
Mar 26, 2007 07:44 PM
spun Vtec
Mar 12, 2005 12:22 PM
homeskillet
Dec 24, 2004 09:22 PM
