bearings?? how do u match em up??
Old Feb 28, 2007 | 09:55 PM
panchovilla760's Avatar
Default bearings?? how do u match em up??
im rebuilding a 91 ls motor, i need to replace my bearing but having trouble finding sizes i did check in the manual but cant figure it out. my rods have the number 3 stamped on them my cranh has the numbers a2 stamped on them and the color of my bearings brown and 1 is yellow? also if i went w/ acl bearing how do i match those up?? thanks
Old Mar 1, 2007 | 08:39 PM
Default Re: bearings?? how do u match em up?? (panchovilla760)
anyone??????
Old Mar 1, 2007 | 09:19 PM
ekb16's Avatar
there is letters on the bottom of your block that you need to match up to the #s on your crank...same with the rods bearings
Old Mar 2, 2007 | 05:30 PM
what about the colors?
Old Mar 2, 2007 | 06:49 PM
ekb16's Avatar
Default Re: (panchovilla760)
after you matched the code on the block and crank/rods, then you can find the colors...here is an example
Old Mar 2, 2007 | 09:26 PM
thanks
blkb18
Feb 5, 2008 08:07 PM
djickabod
Dec 27, 2003 03:14 PM
SPEED123
Jan 20, 2003 10:38 AM
