Desperate need of transmission help
Old Feb 28, 2007 | 05:58 PM
2crxs's Avatar
Default Desperate need of transmission help
Is there any way to tell the differance between a input shaft bearing and a throw out bearing failure? I have a 04 RSX type-s transmission that i just installed, makes a constant loud sqeal/rattle sound. The only time it goes away is if im in gear and accelerating. Any help would be greatly appreciated. Thanks.
Old Mar 1, 2007 | 07:05 AM
Honda Bull's Avatar
Default Re: Desperate need of transmission help (2crxs)
That's probably an input (main) shaft bearing. Is it at idle as well? Meaning, in neutral with the clutch disengaged.
Old Mar 1, 2007 | 10:42 AM
2crxs's Avatar
Default Re: Desperate need of transmission help (Honda Bull)
Yeah, its there at idle with and with out the clutch pressed. I have to pull it out anyway, so I just orderd the bearing.
Old Mar 3, 2007 | 10:00 PM
Bense's Avatar
if you hear noise when:
clutch pedal pressed + vehicle stopped + engine running = TOB
foot off clutch + vehicle stopped + engine running + trans in neutral = ISB
EFRue57
Jan 7, 2009 06:40 PM
mr_nemesis2003
Nov 14, 2006 01:04 PM
numotive
Sep 11, 2005 10:31 PM
ElectronBlueGsr1.8
Jul 27, 2004 05:24 AM
SSBlueDC2
Oct 24, 2003 02:25 PM
