Built turbo b16 what rings should i use?
I have a B16a2 stock sleeved with je 9:1 pistons. 81mm. Im hoping to make 400whp+. I was told to use je file fit rings. What rings would do you guys recomend?
thanks
thanks
If you have the rings that came with the piston then just use those. When re-ringing I have used hastings oem replacement rings and just filed to the desired gap.
