Built turbo b16 what rings should i use?
I have a B16a2 stock sleeved with je 9:1 pistons. 81mm. Im hoping to make 400whp+. I was told to use je file fit rings. What rings would do you guys recomend?
thanks
thanks
Re: Built turbo b16 what rings should i use? (JoePSI)
If you have the rings that came with the piston then just use those. When re-ringing I have used hastings oem replacement rings and just filed to the desired gap.
