n what axles can i use for a H22 into an EF crx
Old Feb 28, 2007 | 11:49 AM
crispynuggets's Avatar
Default n what axles can i use for a H22 into an EF crx
i have a 88 CRX with a H22 with type S lsd in it.. can i use 90-93 axles or do i need custom axles.. Or if you guys have any ideas i would like to hear them..
Old Feb 28, 2007 | 11:55 AM
yz125rider21's Avatar
Default Re: n what axles can i use for a H22 into an EF crx (crispynuggets)
you refering to 90-93 integra axles????but anyways last time I read you need 2 diff axles for that swap...but like exospeed if member has a red rex on ehre with that swap that sells everything for it...I will find link
Old Mar 1, 2007 | 01:09 AM
Default Re: n what axles can i use for a H22 into an EF crx (yz125rider21)
ya i was refering to integra axles.. i have some and they seem to long to even install.. i also read somewhere that i can use 89 integra axles..
Old Mar 1, 2007 | 06:20 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
- get a pair of worn out axles and cut them in half
- take the cv's and cups apart and clean all the grease out of them, a parts washing bin will clean them up very nicely.
- put the car on it's wheels @ driving/racing height. (full weight and compressed suspension) - It's easiest on a drive on hoist but you can do it on a two post hoist if you are creative. The main objective is to put the suspension exactly where it will be as the car is driving.
- install the axle halves back in without the boots - this is tricky, take your time!! You'll need a hand because the cv's will fall out of the inner cups very easily without boots holding them together.
Now you have to determine where you want the inner CV's to be while the car is in motion. To do this, Bottom out the inner half of the axle pushing towards the tranny and then pull it back towards you about .75" to 1.25" (these measurements are off the top of my head, use your best judgment).
The inner cup of the axle is designed to allow the CV's to slide in and out along the axles axis (you'll see what I mean if you didn't already know). As the steering wheel turns and the suspension compresses and decompresses the axles slides within the inner(tranny) cup.
Now that you have established where you want the inner CV to be you can now determine how long you need to make the axle shaft. Pictured below is how to mock up a shorter axle. A piece of pipe is used to keep the two halves of the dummy axle fairly concentric. A few good tacks will keep your mock up assembly together.
At this point you have a complete <FONT SIZE="5"><u>*mockup*</u></FONT> of your axles. Triple check that the axles work under all suspension and steering situations by raising and lowering the car and steering in booth directions.
<FONT SIZE="5">do not be an idiot and attempt to drive the car on welded axles.</FONT> All you have left to do is remove your mockup axles, dissemble them, and bring mockup axle shafts to a good machine shop that can cut splines.
comments/questions welcome, I will revise/edit as needed. </TD></TR></TABLE>
Cut and paste from: https://honda-tech.com/zerothread?id=1479966
the integra axles are too long but i have heard of people using them.. they must of had the motor in a very awkward position that placed the axles are really freaky angles. (very bad idea)
I had the machine shop make my axles from 4130 and use OEM cups/cvs.. I cant break them no matter how hard i try..
Modified by 2point2 at 7:35 AM 3/1/2007
Old Mar 1, 2007 | 03:36 PM
doublethink's Avatar
i know its like forbidden to post non-DIY stuff but:
"EF H-series axles........ etc.
Hasport Axles are made from completely brand new parts and do not require a core like many other competitors do.
Hasport stocks axles for all the swap options offered by Hasport.
These axles are rated to handle up to 200 horsepower at the wheels.
Hasport also offers axles for higher horsepower applications please call for more information on these special order axles."
http://hasport.com/shop/produc...d=130
Also, its a VERY safe bet these guys have the dimensions to make what you want:
http://www.raxles.com/hybrids.aspx
Old Mar 1, 2007 | 03:48 PM
ESP-net
Guest
Posts: n/a
Default Re: n what axles can i use for a H22 into an EF crx (doublethink)
If you purchased a motor mount kit from a Co. give them a ring...
By far the best axle combo is to use the Accord Midshaft 90-93 Ex or Lx model with the custom hybrid Integra axles...
Using the Prelude midshaft and Prelude hybrid axles are **** to problems...*cough EG* for example...
I have done the EF H22A swap quite a few times...
Old Mar 1, 2007 | 06:09 PM
Default Re: n what axles can i use for a H22 into an EF crx (ESP-net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP-net &raquo;</TD></TR><TR><TD CLASS="quote">If you purchased a motor mount kit from a Co. give them a ring...
I have done the EF H22A swap quite a few times...</TD></TR></TABLE>Ya I was trying to refer him to you lol...but I couldnt member who it was
Old Mar 2, 2007 | 03:31 AM
i am using the hasport mount kit. so i think i will use their axles also. thanks for all the help!
Old Mar 4, 2007 | 07:46 PM
i can get the passenger side integra axle in and i haven't yet tried to install the driver side cause i have a bad intermediate shaft that i dont wanna waste time installing it if it will not work. as soon as i can get it rebuilt or a new one i will update..
Old Mar 15, 2007 | 12:12 PM
nomotor's Avatar
if your using the ESP kit will hasport axles work?
Old Mar 15, 2007 | 12:47 PM
ESP-net
Guest
Posts: n/a
Default Re: n what axles can i use for a H22 into an EF crx ( (nomotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomotor &raquo;</TD></TR><TR><TD CLASS="quote">if your using the ESP kit will hasport axles work?</TD></TR></TABLE>
Nope...I beleve they are using the prelude midshaft and prelude hybrid axles which I believe may be giving some troubles...
ESP kit uses
88-89 Acura Integra Driver side off shelf axle
90-93 Honda Accord Ex or Lx model midshaft
88-89 Acura Integra Passenger side axle cut down 1/2" on the shaft with an Accord inner joint on it. Raxles.com sells this axle $160 w/o shipping. Ask for Marty.
Pre_4_Me
Dec 3, 2008 12:25 PM
Ajohatch
Northwest (Sales)
Nov 10, 2005 11:48 PM
LsPower
Nov 19, 2003 08:56 PM
MiniMeonBoost
Jun 4, 2003 06:17 AM
