intake problem (nifty diagram included)
Old Feb 28, 2007 | 11:45 AM
blackrag's Avatar
Default intake problem (nifty diagram included)
i was giving a injen intake. the problem is, i don't have the little o-ring type thing, that fits the air.. thing.. to the body of the intake. (i knew i couldn't explain it.. so i drew you a picture)
it's a good picture.. yes..
where can i get one? can i make one?
Old Feb 28, 2007 | 11:52 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: intake problem (blackrag)
ROFLMAO
Old Feb 28, 2007 | 11:54 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrag &raquo;</TD></TR><TR><TD CLASS="quote">i was giving a injen intake. the problem is, i don't have the little o-ring type thing, that fits the air.. thing.. to the body of the intake. (i knew i couldn't explain it.. so i drew you a picture)
where can i get one? can i make one?</TD></TR></TABLE>
WTF? o-ring? there is no o-ring.
Old Feb 28, 2007 | 11:55 AM
MR.johnson's Avatar
Default Re: intake problem (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
WTF? o-ring? there is no o-ring.</TD></TR></TABLE>
there is no o-ring but there is a plug.
its for OBD2 cars...
Old Feb 28, 2007 | 11:56 AM
Ek Forever y0!
Just plug it and run a breather filter.
That hose connects the two, you can buy a hose that fits or use a breather filter.
Problem solved.
Old Feb 28, 2007 | 11:57 AM
CivicSD's Avatar
i would duct tape it.
Old Feb 28, 2007 | 12:01 PM
xhatchracerx's Avatar
are you referring to the Intake Air Temperature sensor as the "air plug thing." if you are then you can get one of those O-rings gourments from pepboys/kragen/napa/autozone so the sensor will fit nice and tight on the intake
blackrag's Avatar
Default Re: intake problem (CivicSD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSD &raquo;</TD></TR><TR><TD CLASS="quote">i would duct tape it.</TD></TR></TABLE>
how could i stick the little plug in, then?
Old Feb 28, 2007 | 12:02 PM
blackrag's Avatar
Default Re: intake problem (xhatchracerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx &raquo;</TD></TR><TR><TD CLASS="quote">are you referring to the Intake Air Temperature sensor as the "air plug thing." if you are then you can get one of those O-rings gourments from pepboys/kragen/napa/autozone so the sensor will fit nice and tight on the intake</TD></TR></TABLE>
that's my ish! thanks a lot.. do they carry them in all sizes?
Old Feb 28, 2007 | 12:03 PM
they sure do man, i needed one before thats the only reason i know
Old Feb 28, 2007 | 12:06 PM
E46Kid's Avatar
nice intake pic
Old Feb 28, 2007 | 12:07 PM
SiYouLater's Avatar
try using the firewall grommets for wires so they dont get cut up.
Old Feb 28, 2007 | 12:08 PM
blackrag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx &raquo;</TD></TR><TR><TD CLASS="quote">they sure do man, i needed one before thats the only reason i know </TD></TR></TABLE>
where'd you get yours?
blackrag's Avatar
Default Re: intake problem (Em1Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Kid &raquo;</TD></TR><TR><TD CLASS="quote">nice intake pic </TD></TR></TABLE>
word. (actual specs used)
Old Feb 28, 2007 | 12:09 PM
SiYouLater's Avatar
Default Re: intake problem (SiYouLater)
https://www.dormanproducts.com...earch
Old Feb 28, 2007 | 12:11 PM
philosofy1's Avatar
Default Re: intake problem (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson &raquo;</TD></TR><TR><TD CLASS="quote">
its for OBD2 cars...</TD></TR></TABLE>
yes i am aware of this, but he didn't say plug, he said o-ring.
Old Feb 28, 2007 | 12:12 PM
i think i got mine at napa, but i was at kragen today and i saw them there too.
Old Feb 28, 2007 | 12:14 PM
Jakester9500's Avatar
you could probably use a small piece of rubber hose too, just make sure the diameters are the right size
Old Feb 28, 2007 | 12:22 PM
blackrag's Avatar
Default Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">you could probably use a small piece of rubber hose too, just make sure the diameters are the right size</TD></TR></TABLE>
that's what i was thinking.. i'm going to a couple local car stores to see if they have anything.. if not.. home depot time. lol
Old Feb 28, 2007 | 12:26 PM
SiYouLater's Avatar
Default Re: (blackrag)
that's what i was thinking.. i'm going to a couple local car stores to see if they have anything.. if not.. home depot time. lol </TD></TR></TABLE>
Check the Help! section for the grommets in the link above.
rpc08
Oct 12, 2007 12:42 PM
SLiCkNiCk
Honda Civic (2006 - 2015)
Nov 8, 2006 10:53 AM
trooper0641
May 2, 2004 01:27 PM
TylerB
Sep 10, 2003 06:47 PM
kotetu
Jun 17, 2003 07:23 AM
