Hybrid EJ1(EG), on a parts buying spree, tech heads, i need your help.
Old May 21, 2002 | 03:18 PM
Plan B's Avatar
Default Hybrid EJ1(EG), on a parts buying spree, tech heads, i need your help.
Okay, I got the b20 today. The drivers side mount is not like the one that was in my civic, the one that came with the d16z6, it's more offset. for example
-o
<--- civic mount
-o
-o
<--- crv mount
-- o
what do I need to get to get this part in? It's like the last major hurdle I have here. Can I unbolt the bracket off and integra block, they're the right way, like my civic right?
Oh btw, 94 civic ex, with 97 b20b.
[Modified by Plan B, 7:18 PM 5/21/2002]
Old May 21, 2002 | 03:37 PM
Kamin's Avatar
Default Re: Hybrid EJ1(EG), on a parts buying spree, tech heads, i need your help. (Plan B)
use the crv mount
if you dont have it
94+ integra
you have EVERYTHING else figured out?
intake manifold?
transmission t bracket mount?
Old May 21, 2002 | 03:42 PM
Plan B's Avatar
Default Re: Hybrid EJ1(EG), on a parts buying spree, tech heads, i need your help. (KAMiN)
the crv uses a flat piece of metal that bolts on top of the rubber mount (96-00 civics) I don't have that kind of mount. Obviously. I need to know if people take the bracket off an integra mount and use it in place of the one bolted to the crv block.
btw, i had the rear bracket and intake manifold before I ever went to buy the motor. Also, LS ecu, boyeee.
[Modified by Plan B, 7:43 PM 5/21/2002]
Old May 21, 2002 | 03:53 PM
Plan B's Avatar
this is what I need it to be like
this is what i've got, sorta. That's how the crv bolted up.
Sorry to b-troop, and merritr.com, i'll take the pics down if it's a problem./
Old May 21, 2002 | 08:06 PM
Plan B's Avatar
Default Re: Hybrid EJ1(EG), on a parts buying spree, tech heads, i need your help. (AkumaY)
thanks, yeah, i'm going to have to raise hell with the acura guy tomorrow morning.
LagunaSecaEG
23
Sep 15, 2006 07:55 PM
AGENT 99
Dec 18, 2005 09:38 PM
SQ is the SQUAD
Welding / Fabrication
Nov 15, 2005 07:12 PM
paulzy
May 16, 2003 12:05 AM
Scorch7
Dec 27, 2002 02:30 PM
