motor mount bracket?
When i installed my ls motor into my 92 civic hatch the motor mount bracket thing was crooked......and it was sorta hard to get the actual mount in there......wy do u think it was crooked? any ideas?
Re: motor mount bracket? (JSPECSIR)
drivers side upper mount......not the actual motor mount but the bracket....it looks angled...when i did my swap is was kind of hard to get the motor mount in it..
Re: motor mount bracket? (Kruzen510)
okay, picture this......when u pop the hood on a civic 92 civic hatch you look at the drivers side top motor mount and bracket that holds the motor mount. The bracket looks crooked and the motor mount is straight.
Re: motor mount bracket? (LagunaSecaEG)
then you need a 94-95 civic mount or a 94 up integra mount. or you can change the engine bracket fo cheaper to work with the mount you aleady have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LagunaSecaEG »</TD></TR><TR><TD CLASS="quote">i have the 94 integra mount!!!!!!!!</TD></TR></TABLE>
ok so then your saying, your engine bracket is the crooked one ? there are 2 engine brackets, an angled one with 2 studs sticking up, and a straight one with 2 studs sticking up, and a hole for a bolt to go straight down onto it. the first of which takes a 92-93 civic mount(the cheap looking one) the second takes the 94-95 civic and 94 up integra mount.( the nice aluminum one) i had missmatched bracket/mount when i got my swap, and i found it cheaper to replace the engine bracket, than to get the other mount. i hope this helps.
http://www.hondaautomotivepart...MOUNT
the first link is 93(same as 92) and the second is 94(same as 95) the picture sucks but you can see that the location number switches to the other bracket pictured.
heres a better pic of the 94 up teg mount.(also notice#5, nice thing to add to your civic ) i cant find the pics of the brackets right now( gotta go to work), but their on those sights, thats where mine came from.
well damn, why didnt you say the part welded to the subframe. ive been looking at mounts and brackets. if thats bent the car may have been wrecked. bend it back if you can.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">well damn, why didnt you say the part welded to the subframe. ive been looking at mounts and brackets. if thats bent the car may have been wrecked. bend it back if you can. </TD></TR></TABLE>
it's going to be hard to align it back by bending. well atleast trying not to make it look like **** anyways. you best bet take it to a body shop, have them look at it at give a quote on aligning it.
Re: motor mount bracket? (philosofy1)
actually its wierd...the drivers side looks fine on the outside with body lines and everything but the passengers side hood hits the fender and i have bad caster on the side....
im worried about the cost.....i love my car and i dont want to get rid of it and it keeps pissing me off b-c i just want it to be perfect.......i know someone who works at a body shop....here are pics of my car btw
i know how the sideskirts and volk nrs gold rims with a polished lip
Markb16a
15
04-08-2010 01:05 PM
TwoKSiR
Northeast (Sales)
05-16-2007 11:18 AM
