Need: vacuum diagram for GSR in a CRX please
Old Feb 28, 2007 | 08:58 AM
1990hondaHF's Avatar
Default Need: vacuum diagram for GSR in a CRX please
I found a lot of b16 diagrams but those have a few differences when compared to the GSR swap I have. Anyone have a diagram of what goes where?
Old Feb 28, 2007 | 10:13 AM
4thgenhtch's Avatar
Default Re: Need: vacuum diagram for GSR in a CRX please (1990hondaHF)
Is this what ya need?
Old Mar 1, 2007 | 11:35 AM
Default Re: Need: vacuum diagram for GSR in a CRX please (4thgenhtch)
thanks. I'll take a look in the daylight to see if this helps
Old Mar 1, 2007 | 11:51 AM
yz125rider21's Avatar
posted this at the right time!!! I need the purge valve in between line 7 and line 12...anyone know what car I can grab that off of cause I dont have mine on my car anymore sense I use map sensor on TB....thanks
Old Mar 1, 2007 | 01:19 PM
4thgenhtch's Avatar
Default Re: (yz125rider21)
Pretty much any of the dashpot things will work.. There just vaccume switches
Old Mar 1, 2007 | 01:33 PM
ok I guess I go rip one off the firewall(just the vacuum purge right sense my map sensor is on tb?) at pic-n-pull
Old Mar 1, 2007 | 01:53 PM
4thgenhtch's Avatar
yes sir thats all you need..
Old Mar 6, 2007 | 10:00 AM
I have an aftermarket intake manifold therefore I have no IAB....should I run only 1 vacuum to the fuel pressure regulator or should I still have a "t" fitting going to the regulator and the other going to....???...like the b16's?
tempsohc
Jun 19, 2011 06:06 PM
juanchoenuncrx
Dec 26, 2007 05:03 PM
sleep_Rx
Dec 2, 2007 04:43 PM
fast93accord
May 23, 2005 09:31 AM
94cxhybrid-T
Sep 11, 2002 10:17 PM
