my timing keeeps skipping
Old Feb 28, 2007 | 05:13 AM
doodooheadfart's Avatar
Default my timing keeeps skipping
for some reason my timing keeps skipping at the crank gear for some reason. ive reset it twice and have replaced the belt. the tensioner is as tight as it can go. i have no idea where to go next.
Old Feb 28, 2007 | 07:13 AM
thesmogman's Avatar
Default Re: my timing keeeps skipping (doodooheadfart)
The gears do wear. Did you inspect both the crank gear and the cam gear? How's the waterpump?
If you keep going on the motor you will kill it.
When you set the tensioner did you do it by the book and turn the crank a little to move the slack so the tensioner would be set correctly?
Old Feb 28, 2007 | 07:40 AM
hybridmiklo's Avatar
Default Re: my timing keeeps skipping (thesmogman)
I would recommend you replace the tensioner. If you say it's as tight as it can go and it still slips its no longer any good.
Old Feb 28, 2007 | 08:08 AM
dognutz's Avatar
Default Re: my timing keeeps skipping (hybridmiklo)
Or you have the wrong belt.
Old Feb 28, 2007 | 09:18 AM
Bakeoff's Avatar
what block, what head?
Old Feb 28, 2007 | 01:01 PM
it's a stock B20 and im pretty sure i have the right belt, i got it from autozone. i followed the steps in the CRX B16 shop manual but i didn't put slack so the tensioner would set properly, it didn't say anything about it in there. but it may be the tensioner... it still tightens though, just not enough...
Old Feb 28, 2007 | 03:56 PM
hondasarethebest's Avatar
Yeah does sound like a tensioner problem get a new one
Old Mar 22, 2007 | 09:03 AM
so i re-did my timing and tightened the tensioner down all the way and the belt still has quite a bit of slack. ive also rotated it at a couple of different positions to see if it can get any tighter, and it won't.
should i replace the entire tensioner? or just the spring, because a whole new set up will run me next to $100 off of majestic. and a spring is just $3.
here's the link to majestic for a B16 del sol
http://www.hondaautomotivepart...EC%29
Old Mar 22, 2007 | 10:40 AM
DonF's Avatar
Default Re: (doodooheadfart)
Sounds like a GSR belt on a LS/B20. How many teeth? 125 or 126?
Old Mar 22, 2007 | 05:57 PM
a1320addict's Avatar
Default Re: (DonF)
Use an OEM belt, how many teeth on the water pump?
Old Mar 22, 2007 | 06:56 PM
SlowReaction's Avatar
Default Re: (a1320addict)
Have you tried to manually tension it instead of relying on the spring?
Old Mar 22, 2007 | 08:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Use an OEM belt, how many teeth on the water pump?</TD></TR></TABLE>
it's a belt for an LS, got it from auto zone, but tomorrow ill count the teeth
Old Mar 22, 2007 | 08:01 PM
Default Re: (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried to manually tension it instead of relying on the spring?</TD></TR></TABLE>
ive only tightened the tensioner bolt, how would i "manually" tighten it?
Old Mar 22, 2007 | 08:22 PM
JimBlake's Avatar
Look at the picture up above. #21 is the tensioner bolt. When you loosen that, it means the tensioner pulley can move up & down. The spring should pull it upwards, but you can use a coathanger or something to help the spring. Pull upwards to make the belt tight, then lock the pulley in place by tightening the bolt.
Old Mar 23, 2007 | 10:58 AM
havok hybrid's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Look at the picture up above. #21 is the tensioner bolt. When you loosen that, it means the tensioner pulley can move up & down. The spring should pull it upwards, but you can use a coathanger or something to help the spring. Pull upwards to make the belt tight, then lock the pulley in place by tightening the bolt.
ALSO: Check #13.. Make sure the tensioner is sitting on that dowle.
Old Mar 24, 2007 | 02:54 PM
thanks for the good idea
Old Mar 24, 2007 | 04:01 PM
deftonerider's Avatar
did you reinstall (not in the picture) the washer that goes under the lower timing cover. its a wierd looking washer. what it does is it holds the timing belt against the motor. if you forgot to put that on then the timing belt will start to skip teeth.
if you are missing that washer you will have to tear it all apart
Old Mar 25, 2007 | 05:47 AM
slowcar's Avatar
Default Re: (deftonerider)
it is the wrong belt! I had the same exact problem with autozone. they sold me the belt i installed it, and it was to long. i took it back had them look up a timingbelt for a ls came up same part #. so i bought a oem honda timingbelt(like you should)
took it into autozone, had them cross ref the honda timingbelt # and it brought up a totally diff # lol. autozone
Old Mar 26, 2007 | 11:12 AM
Old Mar 26, 2007 | 11:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftonerider &raquo;</TD></TR><TR><TD CLASS="quote">did you reinstall (not in the picture) the washer that goes under the lower timing cover. its a wierd looking washer. what it does is it holds the timing belt against the motor. if you forgot to put that on then the timing belt will start to skip teeth.
if you are missing that washer you will have to tear it all apart</TD></TR></TABLE>
you mean this one?
Old Mar 26, 2007 | 04:43 PM
JimBlake's Avatar
That dished washer holds the belt from walking off the sprocket. Depending on the year of your engine you may have 2 of those (#13) on both sides of the crankshaft sprocket (#17). Or other years you'll have a #12 sprocket with only one dished washer.
Missing that washer shouldn't make the belt loose. But it will allow it to slide outwards, so the belt starts rubbing against the timing cover.
Is the belt still loose?
Verify that your tensioner pulley is positioned correctly.
Verify that you have the right waterpump (how many teeth?)
Verify that you have the correct belt (how long - how many teeth?)
Old Mar 28, 2007 | 12:10 AM
drumking15's Avatar
Default Re: (slowcar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcar &raquo;</TD></TR><TR><TD CLASS="quote">it is the wrong belt! I had the same exact problem with autozone. they sold me the belt i installed it, and it was to long. i took it back had them look up a timingbelt for a ls came up same part #. so i bought a oem honda timingbelt(like you should)
took it into autozone, had them cross ref the honda timingbelt # and it brought up a totally diff # lol. autozone </TD></TR></TABLE>
holy crap...i think this is what is causing my idle problems and timing to be off about 5-6 degrees...fawk!!!
it all makes sense now...off 1 tooth...timing erradic...and misfires...you my friend are a genius...
Old Mar 28, 2007 | 09:16 AM
that looks right
Old Mar 28, 2007 | 07:28 PM
NJcoupe's Avatar
set timing with tensioner loose; rotate motor over 3 teeth; then tighten the belt. Been doin it this way for YEARS
hypnolobster
Jan 24, 2012 08:53 PM
redright9
Feb 7, 2011 11:26 AM
stackz
Jan 7, 2011 05:50 PM
defnu
33
Oct 23, 2009 07:49 PM
mattyturbo
Dec 8, 2007 12:55 PM
