T3/TO4E 60 Trim .82 A/R
COMPRESSOR SPECS:
flow: 53 lbs/min 678cfm
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
supportable of 525whp
you will have to list alot more of your specs to get a good estimate, such as C:R etc. Its a fairly large turbo, i'll look for some dyno charts.
Edit: not my car
Car: EG Hatch
Engine: Stock GSR block, double stacked OEM headgasket, edelbrock IM, itr cams, skunk2 cam gears
Mods: OBX manifold, t3/t04e 60 trim .63a/r, 3" dp, 3" exhaust, custom 2.5" charge pipes, large front mount intercooler (no idea what brand), precision 680cc injectors, 3bar map sensor, walboro 255lph fuel pump, neptune
Tuning at 19psi on c16:
OBX manifold was leaking, this setup ran an 11.2 @ 127
http://forums.evans-tuning.com...=2607
Modified by JoePSI at 10:50 AM 2/28/2007
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
Edit: not my car
Car: EG Hatch
i had that same turbo on my stock gsr. spooled nicely 11 psi at around 4-4500. i was very happy with it. it didnt die off at top end like smaller turbos either!
Here's my setup and tune with the same turbo:
Car: Eg hatch
Engine: 81mm x 87mm, 10:1 compression, p30 head, type r valvetrain, type r cams, cam gears, itr intake manifold, itr tb
Mods: AFI EL manifold a/c compatiable, tial 38mm wg, t3/t4oe 60 trim .82a/r, 3" dp, 3" exhaust, no cat, dumptube, 2.5" AFI charge pipes, large front mount, tial 50mm bov, precision 720cc injectors, walbro 255lph HP pump, 3bar map sensor, AVCR boost controller, Neptune
Tuning at 16psi on 93 octane:
that car was fun to drive, and when vtec hit, it was like a frieght train
DIE THIEVES
Car: Eg hatch
DIE THIEVES
yea i run the same turbo with skunk2 manifold, 70mm tb,720 rc injectors,255 fp,i got it tuned at trick, it hit 258 the at 8 psi one of the first runs then the oil pump shattered from an aftermarket crank pulley...but i alot of people been talking about evans tuning how are they for prices??i know there the best around
legendboy
Nov 14, 2002 06:50 PM
