Oil pressure pinout? Others?
I need to know what pin on the PR3 the oil pressure goes to....thanks
http://b16a.honda-perf.org/wiringb16.htm
doesn't show it...why....not sure...
Modified by 1990hondaHF at 1:44 AM 2/28/2007
Yea I thought thats what you were needing?? Are you talking about the oil pressure sender on the back of the block? Cause if so the only place that goes is right to the cluster for the dummy light and thats it..
Modified by 4thgenhtch at 11:44 AM 2/28/2007
Yes I'm talking about the oil pressure sensor by the oil filter on the back of the block....what do I hook that up to? there are a bunch of wires back there....by the way it's a 90 CRX SI and a GSR engine with a PR3 ECU.....thanks.
