Installing a GSR gague cluster into a 5th. gen. Civic
Old May 21, 2002 | 01:44 PM
sweetcarz02's Avatar
Default Installing a GSR gague cluster into a 5th. gen. Civic
I know it can be done, please help. just looking for a step by step process of how it's done so I can do it, thanks.
Old May 21, 2002 | 01:59 PM
PSU's Avatar
PSU
formerly DxHatchback
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (sweetcarz.com)
hey this is revels, and they will flame you, and tell you to use the search button
Old May 21, 2002 | 02:00 PM
pLaYbOi's Avatar
New User
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (DxHatchback)
try this
http://www.jdmfan.com/technical/cosm...ntegra_cluster/
Old May 21, 2002 | 02:01 PM
I did and nothing came up, lol, so I just figured I would take the kick in the nuts and hope someone would post a link.
Old May 21, 2002 | 02:03 PM
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (pLaYbOi)
yeah that info is for a 6th gen.
Old May 21, 2002 | 02:04 PM
pLaYbOi's Avatar
New User
i dont think the wires should b that different...
get ur cluster n try to compare...see how it goes..
Old May 21, 2002 | 02:07 PM
PSU's Avatar
PSU
just get my si/ex cluster man, lol.
Old May 21, 2002 | 03:20 PM
VtecDeMoN's Avatar
Email my brother at redlinedvtec@hotmail.com he has the wiring info and everything else you'll need. He did back in March and said it was a pretty cake install.
Brian
Old May 21, 2002 | 03:56 PM
Canttx's Avatar
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (VtecDeMoN)
pretty much all you need.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Old May 21, 2002 | 04:02 PM
p0oty's Avatar
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (Canttx)
This is quite tempting, although the fitment is ****.
Old May 21, 2002 | 05:51 PM
racecarpete's Avatar
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (p0oty)
Actually a guy on here retrofits the gsr guages into the civic cluster for 5th gens so fit is stock.
Old May 21, 2002 | 05:56 PM
Kamin's Avatar
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (SilverCivic2k)
CLOSE to stock
Old Oct 20, 2002 | 02:19 PM
Patron's Avatar
so does anyone know how this was done? the cluster fitting in perfectly??? i helped my bro do the wiring and all that works fine, but it didn't fit like in this picture above. help a brotha out
Old Oct 21, 2002 | 06:20 PM
Patron's Avatar
please someone help! i'm about to buy a cluster but i want to be sure it can be done and look nice
Old Oct 21, 2002 | 07:18 PM
RedlinedVTEC's Avatar
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (ptran13)
It's cake, like my brother posted in this thread I did this in my car last march... cake job if you're good with a dremel and soldering iron.
Old Feb 19, 2003 | 05:39 AM
Greggycoupe's Avatar
does anyone know te guy who does the retrofitting into a civic
Old Feb 19, 2003 | 06:14 AM
93hybrid's Avatar
Default Re: Installing a GSR gague cluster into a 5th. gen. Civic (hatchhondagreg)
bondo is your friend ill take pics of mine today or tomorrow. as far as wiring check all the fuses and fuse block when you are done. i dont remember how many i fried.
Old Feb 19, 2003 | 06:35 AM
oldB18EF's Avatar
acura_typer makes gsr clusters for eg's.
Dremetos
Aug 1, 2013 03:31 PM
4drctr420
Honda Civic (2001 - 2005)
Aug 1, 2011 05:00 AM
H22A_EJ2
16
Sep 4, 2007 11:44 AM
Civiclx
Jul 13, 2003 07:37 PM
Lei Siew Long
Jul 24, 2001 08:47 AM
