Installing a GSR gague cluster into a 5th. gen. Civic
I know it can be done, please help. just looking for a step by step process of how it's done so I can do it, thanks.
Re: Installing a GSR gague cluster into a 5th. gen. Civic (DxHatchback)
I did and nothing came up, lol, so I just figured I would take the kick in the nuts and hope someone would post a link.
Re: Installing a GSR gague cluster into a 5th. gen. Civic (sweetcarz.com)
i dont think the wires should b that different...
get ur cluster n try to compare...see how it goes..
Email my brother at redlinedvtec@hotmail.com he has the wiring info and everything else you'll need. He did back in March and said it was a pretty cake install.
Brian
Brian
Re: Installing a GSR gague cluster into a 5th. gen. Civic (VtecDeMoN)
pretty much all you need.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Re: Installing a GSR gague cluster into a 5th. gen. Civic (p0oty)
This is quite tempting, although the fitment is ****.
Re: Installing a GSR gague cluster into a 5th. gen. Civic (SilverCivic2k)
Actually a guy on here retrofits the gsr guages into the civic cluster for 5th gens so fit is stock.
so does anyone know how this was done? the cluster fitting in perfectly??? i helped my bro do the wiring and all that works fine, but it didn't fit like in this picture above. help a brotha out
please someone help! i'm about to buy a cluster but i want to be sure it can be done and look nice
Re: Installing a GSR gague cluster into a 5th. gen. Civic (ptran13)
It's cake, like my brother posted in this thread I did this in my car last march... cake job if you're good with a dremel and soldering iron.
Re: Installing a GSR gague cluster into a 5th. gen. Civic (hatchhondagreg)
bondo is your friend ill take pics of mine today or tomorrow. as far as wiring check all the fuses and fuse block when you are done. i dont remember how many i fried.
does anyone know te guy who does the retrofitting into a civic
Dremetos
08-01-2013 03:31 PM
H22A_EJ2
16
09-04-2007 11:44 AM
Civiclx
07-13-2003 07:37 PM
Lei Siew Long
07-24-2001 08:47 AM
