would the ff-squad ckf (crank angle sensor) bypass trick work to pass emissions in CT?
Old Feb 27, 2007 | 04:56 PM
ricekiller1's Avatar
Default would the ff-squad ckf (crank angle sensor) bypass trick work to pass emissions in CT?
i know it barrows a signal from the CKP. but when scanned will it pass emissions? or do i have to do the sensor install?
Old Feb 27, 2007 | 05:58 PM
95jdmferio's Avatar
bump
Old Feb 28, 2007 | 01:11 PM
Default Re: (95jdmferio)
to the top
Old Feb 28, 2007 | 03:12 PM
jz98ctr's Avatar
it should pass as long as you don't have more than 2 codes at a time
Old Feb 28, 2007 | 03:58 PM
Default Re: (jz98ctr)
well my buddy knows a kid that has everything i need to add a Crank angle sensor to my jdm motor...i just have to buy an oil pump...im getting the sensor and all hardware to hook it up, timing drive gear, and the lower timing belt cover...is this all i need?
Old Feb 28, 2007 | 04:07 PM
sicones's Avatar
Default Re: (ricekiller1)
to run a USDM ecu you need a few other sensors...but your on the right track
read:
https://honda-tech.com/zerothread?id=906684
Old Feb 28, 2007 | 05:24 PM
Default Re: (sicones)
this motor is the 96-97 ITR motor..do the 98+spec ITR's need all these exact modifications as well?
Modified by ricekiller1 at 1:37 AM 3/2/2007
Old Mar 1, 2007 | 04:37 PM
back up!!...??
Old Mar 1, 2007 | 04:41 PM
sicones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 &raquo;</TD></TR><TR><TD CLASS="quote">this motor is the 96-97 ITR motor..do the 98+spec ITR's need all these exact modifications as well?
Modified by ricekiller1 at 1:37 AM 3/2/2007</TD></TR></TABLE>
same exact thing
kaddi88
Aug 25, 2008 05:14 PM
philipwk
Nov 29, 2005 07:54 PM
WhippinTheLude
Oct 20, 2004 06:33 AM
4DRPIMPIN
15
Apr 23, 2004 05:46 PM
sailor
Apr 17, 2003 08:23 AM
