TIMING: cant get to 16* without notching the dizzy????
well guys before i break out the dremel, is it normal to have to notch my dizzy to advance more because i cant get to 16* im on the line nearest the firewall with the dizzy advanced all the way.. wha happen?....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdjizm »</TD></TR><TR><TD CLASS="quote">i have a cam gear set at 3* advanced.. im guessing thats throwing it off, i really like where my cam gear is at right now.. should i notch? btw (d16y8)</TD></TR></TABLE>
...there goes your problem.
there are millions of people with cam gears.. so your telling me to set it to 0?.. all im saying is it ok to notch to make up for that? with my cam gear on 0 my low end is gone.. i have a 105300 cam.. i can put it at 2 and maybe notch less anything below 2 i might as well get out and push the car from idle to 3000rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdjizm »</TD></TR><TR><TD CLASS="quote">there are millions of people with cam gears.. so your telling me to set it to 0?.. all im saying is it ok to notch to make up for that? with my cam gear on 0 my low end is gone.. i have a 105300 cam.. i can put it at 2 and maybe notch less anything below 2 i might as well get out and push the car from idle to 3000rpm</TD></TR></TABLE>
70% of the people with cam gears have it for looks. unless you get the car tuned(and tuner adjusts it for best power) or you have a milled head cam gears are basically pleasing to the eye.
you should never have to notch your distributer. my guess is you just adjusted for what feels best to you. i still wouldnt notch the dizzy
i havent brought it on the dyno but i do know advancing my cam gear gives me alot better low end, its horrible to drive with my cam gear on 0..i can floor it and just bog bog bog, till 3k rpm.. i mean im not even exaggerating, im talking 5-10 miles an hour till 3krpm with the car floored, what do i do?
i have plans for that.. but not till mid year.. for now.. this timing issue is bothering, the cars runs fine how it is by the way, but i kjnow i should be on 16* and looks like im at 14-13* any negatives with running that way?
Ef4doorwagon
13
May 17, 2014 06:09 PM
Power Rev Racing
Aug 12, 2005 04:47 AM
trooper0641
Jun 4, 2004 10:05 AM
