What are the specs of this turbo?
http://cheapturbo.stores.yahoo....html
^ Ignore the picture, it's just a stock photo.
What are the A/R specs of this turbo? I know it's a 50 trim with a .48 hotside A/R, but what is the coldside A/R?
its an E-housing, which are .60, if you maximize the pic and look closely, you can also see it says A/R .60 towards the compressor exit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude »</TD></TR><TR><TD CLASS="quote">its an E-housing, which are .60, if you maximize the pic and look closely, you can also see it says A/R .60 towards the compressor exit</TD></TR></TABLE>
I know that. However, that is not an actual picture. They use that photo for all their turbo's, it's just s stock photo.
Is it not a t3/t04E? E-housings are .60, thats why they use the same pic for all the E turbos, because they all look the same from the outside...the compressor at least.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude »</TD></TR><TR><TD CLASS="quote">Is it not a t3/t04E? E-housings are .60, thats why they use the same pic for all the E turbos, because they all look the same from the outside...the compressor at least.</TD></TR></TABLE>
O, gotcha. Thanks.
O, gotcha. Thanks.
[looks at your sig] Hey, I have a .42ar/.48ar 57 trim t3/t04e...
https://honda-tech.com/zerothread?id=1864718
Look very closely though...
