2001 GSR power door lock problems
Old Feb 27, 2007 | 10:20 AM
j spec's Avatar
Default 2001 GSR power door lock problems
Just got the car and for some reason sometimes when you push the power door lock button the passenger side door doesnt lock. Also when attempting to unlock/open the hatch the passenger side door lock makes an erratic noise like its trying to unlock several times. Just wondering if this is a common problem on integras and if so how i would go about fixing it.
Old Feb 27, 2007 | 10:29 AM
John 07's Avatar
I just started to have exactly same problem on my R starting last week. i wonder how much a steelership would charge to fix??
Old Feb 27, 2007 | 10:51 AM
j spec's Avatar
Default Re: (John 07)
definitely too much
Old Feb 27, 2007 | 10:57 AM
phish4709's Avatar
Default Re: 2001 GSR power door lock problems (j spec)
this happen to my locks when i first got my car. i took off the pannel and you'll be able to see a metal bar. i just shook it loose and put some wd-40 on it and it worked again. team integra has a write up on how to remove a door pannel, it was a quick job and now my locks work fine
Old Feb 27, 2007 | 11:47 AM
John 07's Avatar
Default Re: 2001 GSR power door lock problems (phish4709)
whats this metal bar you are talking about. Also where did you specifically apply the lubrication??
Old Feb 27, 2007 | 04:22 PM
phish4709's Avatar
when you take off your door pannel you will see it, only metal bar connecting to your locks, and i sprayed it right where the lock and bar meet
Old Feb 27, 2007 | 04:47 PM
non_vteccc's Avatar
im definately gonna have to try that with my 94 ls, because ive had the same problem for a couple months now, and its really starting to bug me
Old Feb 27, 2007 | 05:25 PM
phish4709's Avatar
yah give it a shot, really simple
Old Feb 27, 2007 | 06:57 PM
jentegraGS-R's Avatar
i have the same problem too
Old Feb 27, 2007 | 08:21 PM
j spec's Avatar
Default Re: 2001 GSR power door lock problems (jentegraGS-R)
i had this problem on my first integra as well i just never addressed it. i'll have to try that wd-40 trick. Looks like this is pretty common with integras
Old Feb 27, 2007 | 11:33 PM
98GSRDC2's Avatar
yeah its a common problem. i brought it to a shop and fixed it for 40 bucks. he said the gears on for the lock are stripped therefore it always tries to unlock but all it does is make that weird clicking sound
Old Feb 27, 2007 | 11:56 PM
nate_2k5's Avatar
Default Re: 2001 GSR power door lock problems (98GSRDC2)
i had a problem with my driver side not wanting to lock so i switched out the entire assembly...not fun. avoid it at all costs
Old Mar 1, 2007 | 02:32 PM
hindsonher's Avatar
Default Re: 2001 GSR power door lock problems (nate_2k5)
hrm passenger sides does the same thing, but when the car gets warm and has been driven for a while it, then it works fine.
Vic3261
Honda Civic (2001 - 2005)
Jun 17, 2020 10:00 PM
Tonyl507
Mar 9, 2007 06:23 AM
FK00GSR
Apr 10, 2005 06:32 PM
E Swift
Oct 25, 2001 03:37 PM
