ctr momo wheel
Old Feb 27, 2007 | 01:44 AM
gtz's Avatar
gtz
Default ctr momo wheel
did a search and came up with nothing so here goes:
I have a 00ek coupe and the stock steering wheel sucks.
I want a 98-00 CTR steering wheel srs with airbag.
Will my stock ecu operate the airbag correctly? I dont want that **** going off when im getting roadhead
Will this eleminate my signal cancel?
Will i get a cel because of no cruise control or if i cant hook up the air bag what do i do about the srs light?
Ive seen that lots of members have this steering wheel but i havent seen anyone discuss this...maybe because it bolts up like an oem glove and there are no issues but i just want to know before i drop $350 on it
Old Feb 27, 2007 | 03:16 AM
Ricey McRicerton's Avatar
Default Re: ctr momo wheel (gtz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtz &raquo;</TD></TR><TR><TD CLASS="quote">Will my stock ecu operate the airbag correctly? I dont want that **** going off when im getting roadhead </TD></TR></TABLE> No, you'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtz &raquo;</TD></TR><TR><TD CLASS="quote">Will this eleminate my signal cancel?</TD></TR></TABLE>
Will it what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtz &raquo;</TD></TR><TR><TD CLASS="quote">Will i get a cel because of no cruise control or if i cant hook up the air bag what do i do about the srs light?</TD></TR></TABLE>
The SRS light shouldn't come on if you hook up the airbag. You won't get a CEL because of no cruise control. Just make sure you block off the vaccum ports for the CC. It's been a long time since I helped pull one out, so I can't remember exactly what all is involved, but I do remember getting the lines out of the firewall grommets was kind of a pain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtz &raquo;</TD></TR><TR><TD CLASS="quote">Ive seen that lots of members have this steering wheel but i havent seen anyone discuss this...maybe because it bolts up like an oem glove and there are no issues but i just want to know before i drop $350 on it </TD></TR></TABLE>
As far as I know, that's how I understand it to go. Turn the car off, unhook the battery, swap wheels, then re-install. Remember to be especially careful around an airbag. If it goes off it sounds like a gun.
Old Feb 27, 2007 | 09:48 AM
gtz's Avatar
gtz
Default Re: ctr momo wheel (Ricey McRicerton)
Signal cancel, like after you make the turn and your signal automatically clicks itself back to the off position. i had read somewhere that some wheels might eleminate this
Old Feb 27, 2007 | 10:59 AM
Ukrainamese's Avatar
wherever you read that it will eliminate your signal, it's full of bs for this steering wheel, it's all plug n play, i have it on my car and i love it. just remember to unplug your battery when you change it
oh, another thing:
make sure it's the ctr one, if you get the itr one (both look exactly the same) i think it had something to do with getting the itr hub or steering column as well (anyone know?)
Old Feb 27, 2007 | 05:27 PM
gtz's Avatar
gtz
Default Re: (Ukrainamese)
cool, glad its plug and play. thanks for the info
f_l_g
Mar 31, 2006 06:02 AM
Kyles ej1
32
Feb 7, 2005 12:50 PM
jdm jedi
Nov 12, 2003 05:18 AM
Airbag Club
13
Jan 11, 2003 06:22 PM
tEK9
19
Feb 1, 2002 06:58 AM
