rod bearing clearance question
I am building a motor for daily driving, I want to cut through the BS. Should I use thinner bearings to get a larger clearance, or should I stay with the recommended clearances that Helms suggests. I have heard that builders like MASE for example with the EVO build measured cleances for hours/days to find one that suits the build. Is this necessary? The motor is a b16, I would like to make about 350whp using a t3/t4 57trim with a .48 hot side and .60 cold.
Is there a magic number? I just dont want to have to build it twice.
the magic number is .0015" to .0020"
It's up to you what you want out of the motor. Honestly I don't know how big of a difference 5 ten thousandths really makes... and plastigauge only has .0005 resolution (accuracy), so if you were targeting .0017 for example...you wouldn't have a way of measuring that.
On my own build I targeted .0016-18" but according to the plastigauge readings I was somewhere in between .0015 and .0020
I used a stock crank and eagle rods. I measured the rod big end bore diameters to .0001" accuracy and the same with the journals, then calculated which color bearings to go with.
Modified by Speed Industry at 7:22 AM 2/27/2007
Thanks guys. That makes things alot easier.
What do you think about ring gap?
Top ring at .223
2nd ring at .248
I think I would rather have more blow by.
Top ring at .223
2nd ring at .248
