"Loose" noise in rear after replacing all struts...
I switched from stock to KYB GR2's and the ride is improved but the right rear strut is making a very loud noise. It sounds like there is a loose washer or something. I checked all my bolts and they are fine. When I switched struts, I used the stock washer that holds the dust shield instead of the KYB spacer but I did that on all four struts. What should I look for?
when i did my 4-corner strut change on my EF i accidently left one nut on the upper mount a little loose(made huge amounts of noise)....but a simple torque down did the trick....and also check your lug nuts....had that problem also....
i had the same problem. i took off my lowering springs and stock shocks and replaced it with OEM springs with KYb gr-2 shocks. now when i drive, it seems like the car is wobbly and shaky from time to time.
EG8AI
14
Mar 24, 2007 02:41 PM
alfaaay
Mar 31, 2003 06:21 PM
