clicking after shock installation =[
a couple hours ago i finished installing my new KYB AGX shocks with TEIN s-tech lowering springs on my 95 lx 4 door sedan. when i went to go test the ride out, the back shocks started making "clicking" sounds. it kind of soudns like the shocks going up and down. i put everything back where it suppose to except for the dust guards.
anybody know whats the problem?
are you sure you put the springs where it goes to..im talkin abotu the rear springs and the fronts..
the front springs are different from the rear ones...
re check it again see if you got some loose nut or something..
where is this clinking noise coming from???
Re: (ARMED)
im 100% sure about the front and rear springs but there could be a possibility that a nut is loose. im going to check it out tomorrow when there is light. the clicking sound is basically the shock going up and down constantly hitting somethign i believe.
just wondering if anybody has experience with this problem and how they fixed it? this happened to my oem shocks + s-techs when it was missing a bushing but right now im not missing anythign but the dust guards..
Re: clicking after shock installation =[ (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">check for loose nuts or bolts. That's the first step</TD></TR></TABLE>
actually check for OVER TIGHTENED bolts, all the bolts that go through the back lower control arm should only be torqued to 40 foot pounds...
Re: clicking after shock installation =[ (EG8AI)
well i retightened everythign today, took off the whole shock and redid the springs.. still the same problem =[..
how can i tell if its overtighten? if you say 40lbs, how do I know?
the problem only acts in the back driver shock.. everything else is fine =/.. they all have everything! same process done to all 4 and thats the only one thats retarded
I have a similar problem with my Buddy Club racing specs...It seems on mine it is that top nut on the coilover...Just a thought but make sure that thing is tightened down all the way. Hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG8AI »</TD></TR><TR><TD CLASS="quote">how can i tell if its overtighten? if you say 40lbs, how do I know?</TD></TR></TABLE>
Use a torque wrench.
similar thing happened to me....
i didnt put the washers that stop the shock from goin up into the car and they would go up and make a weird noise....
sounds like the problem ur havin....good luck
it is REALLY weird because its only one side. i remember i missed a washer when i only did the springs and thats exacttly what happeneed! now its just weird cuz im not missing anythign at all i guess ill buy that torque wrencha nd make sure everythign is tightened correctly
anybody know! just came back up from putting my car on jackstands.. taking a break before i go do everything over
bump bump bump?
bump bump bump?
4doorH22
01-09-2002 01:07 PM
