how can i tell if its rod knock or head thats knocking ... someone help plzz!!!
Old Feb 26, 2007 | 07:01 PM
hurcombe's Avatar
Default how can i tell if its rod knock or head thats knocking ... someone help plzz!!!
hi guys.. i am going to buy a 1.5lsi but it is knocking quite bad the oqner says i can get a d16z6 head that will fit but dont want to pay a load for it then to find out it is rod knock.. i heard rod knock is really bad so how do i tell or do i find out what it is cheers jamie
Old Feb 26, 2007 | 07:06 PM
2wheelhunter's Avatar
Default Re: how can i tell if its rod knock or head thats knocking ... someone help plzz!!! (hurcombe)
rod knocks are very loud, most valve "ticks" arent as loud, under some circumstances if a rod is knocking, the engine barely starts if at all. dont buy unless its a cheap buy...
unless the valves have a minor tick and just need adjusted, then it will give u endless headaches
Old Feb 26, 2007 | 07:45 PM
Xtream_V's Avatar
Default Re: how can i tell if its rod knock or head thats knocking ... someone help plzz!!! (2wheelhunter)
if it's the vavles it will start to tick faster when you accelerate and if it's rod knock it wont
I'm not sure but i think vavles open and close twice for every one revolution of the crank. I'm not 100% but someone should correct me if i'm wrong.
Old Feb 26, 2007 | 07:50 PM
Default Re: how can i tell if its rod knock or head thats knocking ... someone help plzz!!! (Xtream_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xtream_V &raquo;</TD></TR><TR><TD CLASS="quote">if it's the vavles it will start to tick faster when you accelerate and if it's rod knock it wont
I'm not sure but i think vavles open and close twice for every one revolution of the crank. I'm not 100% but someone should correct me if i'm wrong.</TD></TR></TABLE>
you contradicted yourself, i think what you ment to say is that both are rev-related so its hard to tell buy just reving it,, i would throw it in nuetral and ping it off the rev limiter once or twice, then yould know if its a valve or rod
Old Feb 27, 2007 | 06:07 AM
Xtream_V's Avatar
i think thats what i ment to say..lol not too sure anymore but he can't exactly ping it off the limiter because it's not his yet he's about to buy it. I only heard rod knock for a couple seconds when my friend started up his car heard it then shut it off and started tearing the motor apart a few hours later and my daily's valves are ticking and they sounds completly different.
it's basically an onomatopoeia, tick vs knock. if it's knocking than it's a rod if it's ticking than it's valves.
Thepowderblue
Jul 28, 2012 12:09 PM
Tamotoji
May 14, 2011 02:29 PM
00b18b
Dec 25, 2007 06:24 PM
92b16si
15
May 1, 2007 07:08 AM
limpy
May 30, 2004 10:33 AM
