Difference between Bore and Sleeving?
Old Feb 26, 2007 | 02:28 PM
dezerte's Avatar
Default Difference between Bore and Sleeving?
Sorry I'm kind of new to this, but when you bore the cylinder walls out to 81.5mm, how is it different from sleeving them to, say, 84mm other than just the size?
Old Feb 26, 2007 | 02:52 PM
b16 prospect's Avatar
Default Re: Difference between Bore and Sleeving? (dezerte)
boring and sleeving are two different processes. You can sleeve a block to make it stronger and then you can bore it out to make it bigger, For example if you had a gsr block with is a 1.8 liter you can sleeve and then bore it out to a 2.0 liter.
Old Feb 26, 2007 | 02:58 PM
doood's Avatar
been there done that
Default Re: Difference between Bore and Sleeving? (b16 prospect)
sleeving is replacing the stock sleeves with stronger new iron sleeves. boring is making the cylinders bigger.
Old Feb 26, 2007 | 03:07 PM
dezerte's Avatar
Default Re: Difference between Bore and Sleeving? (doood)
That clears things up a bit. So if you buy sleeves, do you have to get a certain size? Or do you just get iron sleeves and bore them out to the size you want? I ask because it seems like if you tried to bore the stock sleeves to 84mm+, the cylinder wall would be too thin.
(Taken from the LSVTEC thread)
Old Feb 26, 2007 | 03:19 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dezerte &raquo;</TD></TR><TR><TD CLASS="quote">Or do you just get iron sleeves and bore them out to the size you want? </TD></TR></TABLE>
bingo
Old Feb 26, 2007 | 05:50 PM
94IntegraLs04's Avatar
wutttttttt b18c5 2.0 were the hell u get this from 1.8 thts all dude
Old Feb 26, 2007 | 06:12 PM
doood's Avatar
Default Re: Difference between Bore and Sleeving? (94IntegraLs04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94IntegraLs04 &raquo;</TD></TR><TR><TD CLASS="quote"> wutttttttt b18c5 2.0 were the hell u get this from 1.8 thts all dude</TD></TR></TABLE>
what the hell are you talking about?
Old Feb 26, 2007 | 08:44 PM
all-mtr-teg's Avatar
Your quote by bobismoi, says JDM 2.0L
Old Feb 26, 2007 | 08:48 PM
soundFX's Avatar
Default Re: Difference between Bore and Sleeving? (all-mtr-teg)
he quoted it because the dude has no idea what hes talkiing about and he was serious and its funny which is why he quoted him
delsol8017
Nov 7, 2019 08:00 AM
H22Luda720
Mar 20, 2006 06:19 AM
asubennett
Jan 3, 2005 07:27 PM
EGJDM
Apr 20, 2003 12:59 PM
penjaja
Mar 23, 2003 08:17 PM
