Engine shutting off while driving
Old Feb 26, 2007 | 10:27 AM
j lo's Avatar
Default Engine shutting off while driving
Can anyone advise on the situation:
I have a 94 honda accord and recently it started shuttin off while on the highway. I mean i was doing speeds of 75-90 and in the fast lane at that. The engine just shuts off and after I pull over it cranks right back and start to roll again. I have had the main relay replace and the o2 sensors; this problem is still occuring. Anyone with experience on this situation.
Old Feb 26, 2007 | 12:23 PM
russianswty's Avatar
Default Re: Engine shutting off while driving (j lo)
check and change your filters,
change the fuel, and air filter and the pcv valve.
Old Feb 26, 2007 | 12:35 PM
YeuEmMaiMai's Avatar
check your ignition switch, it may be worn........
Old Feb 26, 2007 | 12:36 PM
papunacrx's Avatar
Default Re: Engine shutting off while driving (russianswty)
I'd vote for fuel too...
filter something like that ...
Old Feb 26, 2007 | 01:46 PM
hondadude's Avatar
When the engine shuts off do you have the Oil and Batt light on?
If not I would suspect the electrical part of the ignition switch.
Also the Tach will just drop to Zero.
By any chance, do you have a big long or heavy keychain that swings around as you drive?
Old Feb 28, 2007 | 10:02 AM
j lo's Avatar
Default Re: Engine shutting off while driving (hondadude)
the only light that comes on is my check engine light and then the whole car shuts off. then the oil and battery light comes on.
Old Feb 28, 2007 | 02:32 PM
ali7up's Avatar
the same thing happened to me, the engine light showed code 15 ignition signal output and i had to replace my entire distributor box
Old Mar 5, 2007 | 09:06 AM
Default Re: Engine shutting off while driving (ali7up)
distributor box? what do you mean by the whole box thing
Old Mar 5, 2007 | 09:38 AM
gulfview's Avatar
Follow your sprk plug cables to the round distributor, which can be pulled out from the engine as a unit, dude, after loosening some nuts.
Make sure to note the exact position of it in regard to the engine, so you can replace it the same way. This is also true for the rotor -- mark its direction before you pull the unit out.
Don't forget to replace the rubber o-ring on the shaft, otherwise you will have an oil leak.
Those babies are not cheap. A quick solution may be to pull one out at a salvage yard -- a proper match, natch. Unless you are loaded....
Modified by gulfview at 1:49 PM 3/5/2007
Old Mar 5, 2007 | 11:24 AM
Hawkze_2.3's Avatar
Ignition switch.
Old Mar 5, 2007 | 12:08 PM
krytoi's Avatar
check if u have battery kill switch or anything like that
Old Mar 5, 2007 | 01:11 PM
asolo24's Avatar
i have the same problem right now. one guy says i should change the fuel filter first then if it keeps happening then i should change the gas pump. one guy says just change the gas pump. wat should i do?
Old Mar 5, 2007 | 03:38 PM
hondaguy00's Avatar
Default Re: Engine shutting off while driving (asolo24)
i would say to check your ignition switch.
Old Mar 5, 2007 | 04:12 PM
BLKFLSH's Avatar
Default Re: Engine shutting off while driving (hondaguy00)
One more vote for ignition switch. Here's a link to troubleshoot it. Good luck
http://techauto.te.funpic.org/ignition.php
Old Mar 7, 2007 | 07:44 AM
j lo's Avatar
I had the ignitor changed it is located in the distributor. It seems to be driving fine thus far.
Cody Anderson
Aug 18, 2014 03:35 PM
parisbvamp
Aug 23, 2010 06:02 AM
spiderman_rej
Mar 21, 2008 08:46 PM
legends
Jun 8, 2006 08:36 PM
