Fouled another set of plugs...need advice
ok so if u dont remember about 2 weeks ago i posted that i found out why my car wudnt start. would crank but no fire. it was the plugs, replaced them ran fine then the ignitor went out, replaced that ran fine, now its back to doing the same thing as b4 with the plugs. pulled one same thing as last time. fouled a 2nd set in a week.....bought another set of plugs gunna replace after work, but does any one know why im eating plugs by the week?
Called the ngk rep told me to gap the plugs to .040 and try that, also was told this is signs of the egr system the ports on the intake? possibly i got a bad o2 sensor? all are some my ideas. any input will greatly be appreciated.
http://i47.photobucket.com/alb...2.jpg
thats a pic of the best looking one. the others are lil blacker.
trust me there are bad. that pic i showed u was the best one. the others are solid black and 2 had fuel i believe. ima change my plugs 2 morrow and ill show ya some more pics
hrm ive got a new filter, oive used additive but ill do again. ima re time it Thursday with a snap on timing light. i hope that will fix it. i aint going through a set of plugs every week eff tha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 »</TD></TR><TR><TD CLASS="quote">o2 is like maybe 2 months. cat same. and no cel's</TD></TR></TABLE>
Hmmm...cam and ignition timing is good? Wouldn't hurt to get an AF gauge...
Seems silly, but is your air filter clean. I haven't really heard of a problem like this so I'm sorta just throwing things out.
Here is a site on reading plugs:
http://www.dansmc.com/Spark_Pl....html
I'm guessing you have already looked at something like that.
When reading two-stoke plugs(the only experience I have) you will replace the plug, and then drive in the range in question(1/4 throttle, or 1/2 ect) for a few miles, then kill the engine and coast to a stop. Pull the plug and look at it. That seems alittle extreme in your case as there shouldn't be a problem with the mixture. It almost has to be something(sensor) that controls the mixture. I don't really know enough about these cars, but I'm interested to find out what's up.
Good luck.
Good luck.
iv driven on the new plugs for a day now. no vtec yet. ima time it in a few hrs. then ima give it some hell and see what it does. try and foul em with alot of hi rev thats usually when id start noticing them sarting to act up. so well c. thanks for yalls input ill let ya know what i find out.
