ITBS trottle cable
Old Feb 26, 2007 | 08:17 AM
KMaxwell's Avatar
Default ITBS throttle cable
I was just wondering if anyone had run into a problem with not getting 100% throttle with twm itbs. I just ordered a 95 civic ex throttle cable, i was told that will give me more treads needed to get full throttle. If there is a differant answer i would appresiate it.
Old Feb 26, 2007 | 12:37 PM
SuzukaBlueAP2's Avatar
Default Re: ITBS throttle cable (KMaxwell)
How far off of 100% are you?
Old Feb 26, 2007 | 04:42 PM
KMaxwell's Avatar
64% is the max i get
Old Feb 27, 2007 | 05:30 AM
Default Re: (KMaxwell)
I just did some quick researche and it seems as though the 92-95 Civic cable is the way to go.
As far as the bracket, I have found that some people have had to make a custom bracket.
Hope that helps...
Old Mar 1, 2007 | 12:24 PM
KMaxwell's Avatar
Default Re: (SuzukaBlueAP2)
thanks, i am using a 94 civic cx cable now and i ordered a 95 civic ex. I came in today so i will let you know if thats the trick. Thanks again
Old Mar 2, 2007 | 12:04 PM
KMaxwell's Avatar
well i dont see any differance with a 95 civic ex and a 94 cx throttle cable. I then used a 94 gsr cable and still the best i can get is 70% from the tps. Now i was told to bend the accel pedal where the cable attaches. Any other thoughts or anyone with itbs have these issues
Old Mar 2, 2007 | 12:12 PM
I don't think I'd go as far as bending the accelerator pedal.
what about the bracket for the cable? Can it be bent or relocated anywhere?
Old Mar 2, 2007 | 12:26 PM
KMaxwell's Avatar
maybe im looking to hard but regardless of the cable. 1 the overall pull of the accel. pedal is the same, 2 the the cam for the throttles has to rotate more than the amount of the accel pulls. Does that make sence. and if so moving the point at which you mount the cable wont matter.
Old Mar 3, 2007 | 07:37 AM
KMaxwell's Avatar
Anyone else have any of these problems. Or did just fab up new brackets or new cam set up?
cpl rampage
May 25, 2010 05:57 AM
Trak_Day
Aug 21, 2004 12:37 PM
SupaFly_Honda
Jan 29, 2004 06:52 PM
Yellow Dragon
May 10, 2002 06:37 AM
