taillight problem...
Old Feb 26, 2007 | 07:50 AM
vtec770's Avatar
Default taillight problem...
ight well when i turn the lights on my passenger taillight is brighter than the driver. and when i hit the brakes the passenger side goes dimmer whereas the driver side is normal. i put the same bulbs in the two and the passenger side doesnt work so i put the another bulb which is a lil bigger(came with it) and went way brighter like stated above. the two bulbs i put in were meant for it the one that was in before came with the car when i bought it from the guy. the driver side works fine. if this helps its a '98 gs.
Old Feb 26, 2007 | 08:04 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: taillight problem... (vtec770)
You somehow put the bulb in backwards. I think it takes an 1157 bulb.
Old Feb 26, 2007 | 08:13 AM
vtec770's Avatar
ill see but...wtf backwards??? they have 2 pins on the side and one is a lil raised than the other.
Old Feb 26, 2007 | 08:46 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (vtec770)
What is this "other" bulb? Does it have markings? Someone may have forced it into the socket which makes the 1157 not fit anymore.
Old Feb 26, 2007 | 10:45 AM
vtec770's Avatar
well i just pulled both out again and the passenger side says 2057k s383m3 with a silver metal case. and the driver side says 2057 hungary >c5 with a copper metal case. and both have the 2 nubs under it
Old Feb 26, 2007 | 11:17 AM
Dogginator's Avatar
Daisy... Daisy...
Check the wiring on the socket with a multimeter. Perhaps the socket was replaced, modified, or damaged. This is a bit unclear to me:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec770 &raquo;</TD></TR><TR><TD CLASS="quote">i put the same bulbs in the two and the passenger side doesnt work so i put the another bulb which is a lil bigger(came with it) and went way brighter like stated above.</TD></TR></TABLE>
Do all bulbs work properly on the driver side?
Old Feb 26, 2007 | 01:27 PM
vtec770's Avatar
yea they do its just in the passdenger side they go brighter and when i hit the brakes it goes dimmer...like the opposite of what it should do. buy ill go out and buy 2 1157 bulbs and see if that changes anything.
Old Feb 27, 2007 | 11:19 AM
vtec770's Avatar
solved.... i needed new bulbs
dstngu4dr
Oct 20, 2009 09:59 PM
Senbonzakura
Jan 4, 2005 07:48 PM
integra99blue
Jan 15, 2002 06:39 AM
puckster02
Oct 3, 2001 03:29 PM
Night Kid
Sep 12, 2001 08:42 PM
