ls transmission problem need help
Old Feb 26, 2007 | 07:14 AM
irideslammed5021's Avatar
Default ls transmission problem need help
Just put new transmission on my lsvtec its an ls tranny and when the car is off it shifts fine but when the car is on it is real hard to go into gear I bled the tranny several times and can't figure out what's wrong does anyone know?
Old Feb 26, 2007 | 07:48 AM
pdiggitydogg's Avatar
how is the clutch
Old Feb 26, 2007 | 08:10 AM
Default Re: (pdiggitydogg)
the clutch is in good condition and there is fluid in the tranny
Old Feb 26, 2007 | 08:14 AM
Eran's Avatar
HT White Ops
Is this a B18A or B18B?
And hows your clutch fluid?
Old Feb 26, 2007 | 09:20 AM
Default Re: (Eran)
the fluid is good the resoiver is fully
Old Mar 13, 2007 | 02:19 PM
sr_teggy's Avatar
Default Re: (irideslammed5021)
have you figured out your problem. i just installed my clutch and have the same exact problem
Old Mar 13, 2007 | 02:42 PM
6speed-ferio's Avatar
Default Re: ls transmission problem need help (irideslammed5021)
i have the same problem also cant firgure it out
Old Mar 15, 2007 | 01:33 PM
Auby's Avatar
Check your Slave cylinder and master they might be bad. Also try bleeding it.
Old Mar 20, 2007 | 05:50 PM
Default Re: (Auby)
sorry so late got it running about a week ago, the motor was sitting on a slant, but its still not working the way i want it to, i need to vacuum bleed the clutch and check the slave and master just to make sure, thanks for all the help though guys if i can be any help just leave me a message
Snowman3645
Transmission & Drivetrain
Jan 4, 2009 08:46 PM
97integraLS911
Dec 14, 2008 08:58 PM
97integraLS911
Apr 18, 2008 08:19 AM
hialeahzbg
26
Jun 7, 2006 04:31 AM
Drizzo
13
Aug 5, 2004 08:44 AM
