sohc v-tech Boost or B16b Boost
Old Feb 25, 2007 | 08:31 PM
civicdude215's Avatar
Default sohc v-tech Boost or B16b Boost
I have a 93 civichttps://honda-tech.com/zeropost?cmd=newtopic&id=1#
https://honda-tech.com/zero...&id=1# thinkin about boost or swap........let me know, swap or boost the one i have now. Want to get about 250Whphttps://honda-tech.com/zeropost?cmd=newtopic&id=1#
Old Feb 25, 2007 | 08:37 PM
D16Clunkin's Avatar
Default Re: sohc v-tech Boost or B16b Boost (civicdude215)
do you have a budget? if not then by all means boost the b16. if your only lookin to spend a grand then just boost the d
Old Feb 25, 2007 | 08:43 PM
Default Re: sohc v-tech Boost or B16b Boost (D16Clunkin)
how hp will a get after tunnin it?
Old Feb 25, 2007 | 08:53 PM
D16Clunkin's Avatar
Default Re: sohc v-tech Boost or B16b Boost (JJSpecTuning)
[QUOTE=and i wouldn't boost the b16b, that motor is almost double the price of a b16a swap and i'm pretty sure you could use that money towards a better setup[/QUOTE]
amen to that. an LS (b18b) would be 452562 times better to boost than any b16 and the price is about half. madly out torques a b16
Old Feb 25, 2007 | 09:01 PM
hahahaha thats funny my friend have a boost LS and he loves it....350whp feels fast.......i was thinkin about doin da same but im not tryin take he's shine.....lol
Old Feb 25, 2007 | 09:07 PM
D16Clunkin's Avatar
theres plenty of different setups you can run for different things, just depends on what you want. build a better setup and beat his *** up and down the street
Old Feb 25, 2007 | 09:17 PM
hahahaha.............yeah.......with LS V-tech? or sohc boost
Old Feb 25, 2007 | 09:23 PM
broketuner-Sol_Si's Avatar
I agree with the other responses, ls and boost for more whp and tq than an sohc
a simple equation you should know is b16b + boost= BOOM!!!!!!!!!!!!!!!!!! (unless of course you go with lower comp. pistons, but then WTH would be the point of getting a b16b?...b16b is a good motor for NA only....they are basically a b16a with a factory port and polished head and a shitload more compression)
1 thing to consider is that stock Bseries replacement parts are typically much more than a same SOHC part(ex: Head, block)
what's your budget?
Old Feb 25, 2007 | 09:31 PM
Default Re: sohc v-tech Boost or B16b Boost (broketuner-Sol_Si)
expletive it do the k20 swap ...............hahaha in my dreams expletive cost to much uh?
Old Feb 25, 2007 | 10:04 PM
Richard...'s Avatar
i think this thread should help clear this up
(read the whole thread there are some really good points/arguments as to why to stick with the D check it out
https://honda-tech.com/zero...age=1
Old Feb 28, 2007 | 08:32 PM
tc07's Avatar
use the red button in the top right corner labeled "Search" and look under forced induction. threads for both d and b series in there...
Old Feb 28, 2007 | 08:36 PM
knockout's Avatar
a simple equation you should know is b16b + boost= BOOM!!!!!!!!!!!!!!!!!! (unless of course you go with lower comp. pistons, but then WTH would be the point of getting a b16b?...b16b is a good motor for NA only....they are basically a b16a with a factory port and polished head and a shitload more compression)</TD></TR></TABLE>
dont bring up this arguement again.
to the OP: if this is your first turbo car I'd say search around and read more, then boost your D. Only reason I say that is because its cheaper.
Old Feb 28, 2007 | 08:44 PM
muhaMan's Avatar
id boost single cam OR swap in b18b and boost that instead of b16
Old Feb 28, 2007 | 11:45 PM
hatchnideas's Avatar
Default Re: (muhaMan)
as for making more power boosted on a b18b than a boosted d not really unless you want to go above 400 at the wheels seen more than a few 400+ built d's now. youll save a bit of money up front with the d by not having to pay for the new swap and with a decent build you could hit 250 or more pretty easily on pump gas... that and d series are cheaper to replace if something pops
Old Mar 1, 2007 | 12:11 AM
JDM_Frijoles's Avatar
All of your answers can be found here---------------&gt; https://honda-tech.com/zerosearch or here----------&gt;
http://www.beesandgoats.com/bo....html
Old Mar 15, 2007 | 12:08 AM
EF7's Avatar
EF7
Default Re: sohc v-tech Boost or B16b Boost (j1mmyyyyy)
Did anyone read the title " sohc v-tech Boost or B16b Boost"
What a waste
Old Mar 15, 2007 | 12:14 AM
ke98248's Avatar
Default Re: sohc v-tech Boost or B16b Boost (EF7)
Boost is the way to go.&&
But get it done right, or b00m goes your motor!
2percent7
Jun 4, 2008 04:16 AM
twenty
Jun 13, 2005 04:07 PM
drvfast
Nov 16, 2003 10:13 PM
