Turn Key, Nothing for 5 sec., Then starts.
Old Feb 25, 2007 | 08:04 PM
The Captain's Avatar
Default Turn Key, Nothing for 5 sec., Then starts.
It's pretty cold here in PA, so maybe that has something to do with it, but lately when i get in and try to start my car, i turn the key completely and not a thing happens, no starting noise, nothing. Then after having the key held for like 5 seconds, it cranks and starts like nothing happened. Any ideas? I even tried leaving the key in acc. for a few seconds to get the fuel pump going, thinking that might help a little, but no difference. Only has been happening every three or four tries from dead cold. It's a 98 base 5pd.
Old Feb 26, 2007 | 12:08 AM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: Turn Key, Nothing for 5 sec., Then starts. (The Captain)
Main relay?
I was having similar problems with my lude a while back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">OK basically to start off an easy way to see if its the main relay is that you turn the key to the on position (do this when the car isnt starting) the check engine light should turn on then turn off a second later if it doesnt turn on or it doesnt turn off then its probably your main relay. also It sounds dumb but if the light stays on kick the lower dash by your left foot if the light goes off its you main relay.
the relay is located down by the left kick panel up on the wall. they say its somewhat hard to get to. I hope this works. or helps
Old Feb 26, 2007 | 01:50 AM
madcatz's Avatar
there is a FSB about this in the 5th gen
What all do you have on your keychain?
Have yo had the Factory Ignition recall done?
There is a sensor in your key that is part of your immobilizer. Make sure nothing but the key and maybe your chain fob for your alarm/keyless entry is the only thing there. Mine did this for the longest time and I had it taken into honda thinking the Recall hasnt been done....there is a bulletin about it.
But like said above it may be your Main Relay....probably not, but it still is an option.
When you try to start, look for the blue key display in your gauge cluster on the right hand side. Tell us what it is doing while you try to start the car and it does not start
Old Feb 26, 2007 | 10:36 AM
Default Re: (madcatz)
on my keychain i have just house keys and such, no electronics of any kind. The recall was fixed by the previous owner. Next time it does it, i'll take a look at the dash and tell you if anything is happening. Other than that, it is as if i'm not even turning the key when i turn it. Doesn't crank, nothing of the sort. But like i said, after holding the key in the start position for like 4-5 seconds it starts up like normal, as if i had just turned the key.
Old Feb 26, 2007 | 10:50 AM
RA102725's Avatar
I've been meaning to make a post about this.. I own a fourth gen.. same things been happening during this winter... i replaced the main relay last year because it wouldnt start in the heat.. any ideas?
Old Feb 26, 2007 | 12:14 PM
jardolei's Avatar
I have exactly the same problem, just that it only happens once in a while, not enough to get on my nerves yet...
Base 5th gen
Old Feb 26, 2007 | 01:11 PM
Default Re: Turn Key, Nothing for 5 sec., Then starts. (jardolei)
mine's every now and then too, anyone have any solutions?
Old Feb 26, 2007 | 01:39 PM
MN_BB4_Si's Avatar
it could quite possibly be your ignition switch. i know saturn ion's have a sever problem with their ignition switches failing when it's cold. at first they wont start at all, then let em warm up and they'll usually start. so i'd check that out for sure.
-Jason
Old Feb 26, 2007 | 08:08 PM
madcatz's Avatar
if you can tel me what your immobilizer is doing I can try and help you.....Im pretty positive your just getting interference with your key to the Imob unit
FATKID87
19
May 27, 2011 07:31 AM
bpetruzzo
Jan 8, 2008 05:48 PM
ham
Mar 9, 2006 02:25 PM
Chief Brody
Aug 30, 2005 08:58 AM
slowexcoupe
May 23, 2005 08:48 PM
