turbo manifold for crx
Old Feb 25, 2007 | 06:58 PM
Turbo_Mike's Avatar
Default turbo manifold for crx
Hey guys, i'm looking to upgrade my current setup in my b16 crx. I'm running a log manifold with ext. gate and crush bent 2.5" downpipe.
I think i'd like to find a manifold like this:
Anybody run something like this in crx? Do they make these manifolds with the wastegate pointing off to the side? Because it looks like there would be clearance issues with i/c or radiator.
Old Feb 25, 2007 | 11:35 PM
Redline130's Avatar
Default Re: turbo manifold for crx (Turbo_Mike)
Unless you use a half sized radiator, you will run into clearance issues. Have you thought about using an InlinePro manifold?
Old Feb 26, 2007 | 04:49 AM
Autoworks's Avatar
I've used 2 different versions of that mani on my CRX. Both worked great. The one I currently have has the wastegate facing forward, the 1st one I had had the wastegate off to the side. You will have to use a 1/2 sized radiator either way it goes. If you get one with the wastegate off to the side then you will need to run a slim fan as a pusher. I've got pics of both somewhere.
Old Feb 26, 2007 | 08:17 AM
Turbo_Mike's Avatar
Default Re: turbo manifold for crx (Redline130)
I've considered the inline pro, and still havent ruled it out as an option. The other thing i forgot to mention is i'm using a pwr custom dual backdoor intercooler. Ideally i'd like to get the compressor output as close to the i/c inlet as i can, but its a 30x8 so its gonna be tough to throw the turbo over that far...?
I have a 77 civic rad in there now and i get hot on the highway, so i may be upgrading to the full race rad soon. Any pics u can find for me autoworks would be great man!
Old Feb 26, 2007 | 08:35 AM
Autoworks's Avatar
Front wastegate, sits right behind the bumper support (1/2" clearance)
I'll find a pic of my other one
Old Feb 26, 2007 | 09:51 AM
93supercoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_Mike &raquo;</TD></TR><TR><TD CLASS="quote">
I have a 77 civic rad in there now </TD></TR></TABLE>
Thats funny.
Old Feb 26, 2007 | 10:17 AM
Turbo_Mike's Avatar
Default Re: turbo manifold for crx (93supercoupe)
It works pretty good except that i overheat on the highway. It was 2" shorter than the eg so i can just about close my hood w/o it hitting.
Heres my current setup, but i had to make a loop of piping about 2 feet long to hit the intercooler. I wanna get that turbo moved over about 2" so it can be lined right up with ic once i clock it 90 degrees
Old Feb 26, 2007 | 12:39 PM
Redline130's Avatar
Try using a 95-99 Neon radiator. Half size and it clears the hood. Fits very well. I use it on my race car, works great. (However, I do have an electric water pump too.)
Old Feb 27, 2007 | 12:25 PM
Turbo_Mike's Avatar
Have any pics of that setup?
I think i'm just gonna fork out for the full-race radiator to compliment my tractionbar. Just wanna find a manifold that will fit in there well enough to fit the tial and go 3" dp
Old Feb 27, 2007 | 01:18 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_Mike &raquo;</TD></TR><TR><TD CLASS="quote">Have any pics of that setup?
I think i'm just gonna fork out for the full-race radiator to compliment my tractionbar. Just wanna find a manifold that will fit in there well enough to fit the tial and go 3" dp</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1863114 &lt;-- There's a couple of pics of my set-up in this thread. Not real good shots of the radiator, but you can kind of get an idea.
Old Feb 27, 2007 | 02:13 PM
EJ1 wilcox's Avatar
I'm using a mini ram and neon radiator as well. The mini ram is made by South florida performance, but you get the idea.
one thing I liked about this mini ram is the wastegate elbow comes out of the collector, which means the wastegate is placed just perfectly for this chassis. I have tons of pics so if you need any more just let me know.
Old Feb 27, 2007 | 04:29 PM
lysergican's Avatar
i use a lovefab.com mini-me eq, love it and fits great, although i did get full-race's ef radiator to clear the 3in. dp and 44mm wg.
sorry bout the blurry pics, i was in a rush, lol.
Old Feb 27, 2007 | 04:36 PM
Autoworks's Avatar
Default Re: turbo manifold for crx (macroresin)
^^I like that. My friend made one identical to that for his H22
Old Feb 27, 2007 | 04:47 PM
EJ1 wilcox's Avatar
Default Re: turbo manifold for crx (Autoworks)
Ooohhh... that el mani and radiator setup is money.
Old Feb 27, 2007 | 04:54 PM
lysergican's Avatar
Default Re: turbo manifold for crx (EJ1 wilcox)
yeah, tell me about it!!! a couple years before i ran a inline pro ss t3 mani and 38mm wg, while the radiator was cocked to the side, it drove me insane. i had to do something about it!! :-p
Old Mar 3, 2007 | 09:07 PM
Turbo_Mike's Avatar
Thanks for the pics man
Old Mar 16, 2007 | 05:52 PM
Turbo_Mike's Avatar
up for my ideas on how to run mysetup wtih backdoor intercooler plz
asilaydying1984
Jul 24, 2005 08:06 PM
2SLO
Sep 29, 2004 07:45 AM
highmilehatch
Jul 14, 2003 03:37 PM
