doing d15b vtec swap need some pointers
Old Feb 25, 2007 | 03:31 PM
no_rice_please's Avatar
Default doing d15b vtec swap need some pointers
okay i'm doing the d15vtec swap and i need to know what ecu to run without having to chip it
will the p28 work how will it be?? too rich??? too lean????
i also heard that it need the p08 ecu will it be plug and play and is that the correct ecu???
also how do i wire up the vtec on it to make it run 100%??? (pictures would be great but ecu pinout will do)
thats all i can think at the moment but i'm sure i have some more question
and don't flame please i did search
Old Feb 25, 2007 | 03:37 PM
Luserkid's Avatar
Default Re: doing d15b vtec swap need some pointers (no_rice_please)
P28 ecu with a 4wire o2 sensor runs alot better then the P08 with single wire.
Old Feb 25, 2007 | 04:09 PM
big-cat's Avatar
you should look up some detailed directions on the web some where before u do anything else. no offense im just saying im pretty sure if u found some pretty good instructions that would help u out. p28 ecu should be fine.
Old Feb 25, 2007 | 04:14 PM
MR.johnson's Avatar
Default Re: doing d15b vtec swap need some pointers (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">P28 ecu with a 4wire o2 sensor runs alot better then the P08 with single wire. </TD></TR></TABLE>
yes. a p28 will work just fine... it may be alittle rich.
Old Feb 25, 2007 | 07:27 PM
so what would i need to do to be able to use the 4 wire o2... do i just change the wiring harness thats on the engine
Old Feb 25, 2007 | 07:29 PM
Default Re: (big-cat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat &raquo;</TD></TR><TR><TD CLASS="quote">you should look up some detailed directions on the web some where before u do anything else. no offense im just saying im pretty sure if u found some pretty good instructions that would help u out. p28 ecu should be fine.</TD></TR></TABLE>
instructions on what???
rmriffle
10
Mar 9, 2008 10:47 PM
laoboisosilly
Mar 10, 2007 07:59 AM
zx2gotboost
Apr 23, 2006 08:20 AM
extrmeboost
Nov 7, 2005 10:55 AM
trooper0641
Apr 7, 2004 10:12 AM
