conv harness, IAC valve code
Old Feb 25, 2007 | 05:53 AM
ZUL8R's Avatar
Default conv harness, IAC valve code
what wire do i need to move to get rid of the cel? 98 civic dx obd2 to obd1 conversion. any help much appreciated
Old Feb 25, 2007 | 05:54 AM
sicones's Avatar
Default Re: conv harness, IAC valve code (ZUL8R)
why did you swap to OBD1, and doesn't ODB1 use a 2 wire IACV for all engines??, you have a 3 wire
Old Feb 25, 2007 | 05:59 AM
ZUL8R's Avatar
Default Re: conv harness, IAC valve code (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">doesn't ODB1 use a 2 wire IACV for all engines??, you have a 3 wire</TD></TR></TABLE>
yes thats the problem, one of the three wires needs to be moved, i just dont know which one it is
Old Feb 25, 2007 | 06:04 AM
sicones's Avatar
you need to swap intake manifolds, once again, why did you swap to OBD1?
go here, OBD2A
http://technet.ff-squad.com/
Old Feb 25, 2007 | 06:06 AM
ZUL8R's Avatar
eliminate the much hindering speed gov.
Old Feb 25, 2007 | 07:04 AM
ketchup214's Avatar
disconnect the orange let it hang or tape it off , then just do the pinouts it everywhere on this site thanks
Old Feb 25, 2007 | 01:34 PM
ZUL8R's Avatar
Default Re: (ketchup214)
i read that if you move pin A14 to the empty A12 location, and then unpin A13 and leave it unpinned (taped off) because it is useless.. Can anyone back this up?? Thanks...
Old Feb 25, 2007 | 04:23 PM
sicones's Avatar
Default Re: (ZUL8R)
you cannot control a 3 wire IACV with a 2 wire ECU, you need to swap intake manifolds to a manual Y8 and you have to do that ecu pin switch
Old Feb 27, 2007 | 01:50 PM
ZUL8R's Avatar
Default Re: (sicones)
anyone else have any suggestions, im still trying to get with JE so they can explain what i should do.. I might have a chance to dyno this weekend so i wanna try to figure this out.
Old Feb 27, 2007 | 02:05 PM
Malakai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ketchup214 &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the orange let it hang or tape it off , then just do the pinouts it everywhere on this site thanks</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R &raquo;</TD></TR><TR><TD CLASS="quote">i read that if you move pin A14 to the empty A12 location, and then unpin A13 and leave it unpinned (taped off) because it is useless.. Can anyone back this up?? Thanks...
do these
Old Feb 27, 2007 | 03:14 PM
EE_Chris's Avatar
Default Re: (Malakai)
If you do have a 3-wire IACV, it'll never be controlled by an ECU that originally controlled a 2-wire IACV and vice-versa, as sicones already pointed out.
h22accord101
Mar 3, 2015 12:44 PM
SiR-T
Aug 8, 2014 05:53 AM
2nrz
Jan 21, 2008 08:11 PM
GDM Z28
Nov 4, 2004 04:08 PM
Pfieff
Dec 2, 2003 11:45 AM
