Degreeing Cams - I'm confused about Skunk's method
Old Feb 24, 2007 | 09:08 PM
erikiksaz1's Avatar
Default Degreeing Cams - I'm confused about Skunk's method
This is taken directly from Skunk2's catalog:
Now, I'm a bit confused about Step 3:
A) You rotate the crankshaft until the pointer specifies that your cam is currently at the peak lift, which you know by the cam specifications.
B) After that, it says to loosen the cam gear bolts, and to rotate the crankshaft until the indicator is showing that the cam is at peak lift. Then tighten the cam gear bolt.
But I don't understand step B. If you already rotated the crankshaft and found peak lift in A, what's the point of B?
Old Feb 26, 2007 | 04:16 PM
jeef84's Avatar
Default Re: Degreeing Cams - I'm confused about Skunk's method (erikiksaz1)
Step 3 says to rotate the camshaft after loosening the cam bolts. Not the crankshaft.
Part A puts the piston and crankshaft in the correct position. Part B matches that position with peak lift of the lobe.
1BADEGDC2
Jul 9, 2008 06:45 PM
TB123
Mar 24, 2008 01:36 PM
honda_ek9
Feb 23, 2008 07:28 PM
The Si
Feb 22, 2007 10:36 PM
RoB316
Aug 29, 2006 07:25 PM
