I Really Need Help
Old Feb 24, 2007 | 07:30 PM
nicko360's Avatar
* B A N N E D *
Default I Really Need Help
Okay, I've been trying to work out a few problems on my supercharged z6
it has an iritac idle which I tried to fix earlier (https://honda-tech.com/zerothread?id=1904264) but no luck, now i messed with the screw on the throttle body, then the car gave code 3, which I haven't been gettingbefore, then I turned the screw all the way inward and the code went away, but now the car dies 5 seconds after it starts? If I give it gas it stays alive, but once I take my foot of the gas it dies, I installed the map controller for the supercharger earlier today, but it ran fine then, still with the eratic idle.
I would appreciate any kind of help possible
Thanks
Old Feb 24, 2007 | 07:31 PM
Eran's Avatar
HT White Ops
You need to tow your car to a skilled mechanic. Things just keep going wrong.
Old Feb 24, 2007 | 07:36 PM
nicko360's Avatar
* B A N N E D *
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">You need to tow your car to a skilled mechanic. Things just keep going wrong.</TD></TR></TABLE>
its kinda been the same problem all along, something map related, ive had a few mechanics from honda-tech and some that I know from around look at it, all ive found out so far is that if one of the holes i the throttle body is covered the car idles perfect
Old Feb 24, 2007 | 07:41 PM
Eran's Avatar
HT White Ops
Default Re: (nicko360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">
its kinda been the same problem all along, something map related, ive had a few mechanics from honda-tech and some that I know from around look at it, all ive found out so far is that if one of the holes i the throttle body is covered the car idles perfect</TD></TR></TABLE>
Then cover the hole.
Old Feb 24, 2007 | 07:47 PM
nicko360's Avatar
* B A N N E D *
Default Re: (Eran)
Then cover the hole.</TD></TR></TABLE>
is that okay though? Will I have any problems down the line?
Old Feb 24, 2007 | 07:48 PM
Eran's Avatar
HT White Ops
is that okay though? Will I have any problems down the line?</TD></TR></TABLE>
Well, what is the hole from? Did you forget a sensor, or did you remove a vacuum nipple?
Old Feb 24, 2007 | 07:50 PM
crispy93's Avatar
as long as you didnt miss a sensor or anything, covering the hole should be fine.
Old Feb 24, 2007 | 07:53 PM
fmrprojects's Avatar
Default Re: (crispy93)
its the fast idle valve under your throttle body. its stuck open or close. take it out and adjust it or replace it with another one. it has 3 10mm bolts holding it on. its right under the throttle body. i think thats the problem
Old Feb 24, 2007 | 07:56 PM
nicko360's Avatar
* B A N N E D *
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">its the fast idle valve under your throttle body. its stuck open or close. take it out and adjust it or replace it with another one. it has 3 10mm bolts holding it on. its right under the throttle body. i think thats the problem</TD></TR></TABLE>
okay ill go try that now and let you know, if I replaced the throttle body would that work? Also why would the car just start dieing on me 5 seconds after it starts?
Old Feb 24, 2007 | 09:27 PM
nicko360's Avatar
* B A N N E D *
I figured out why the car was dying, the ecu wasn't grounded....
but I took the throttle body off, my friend has an F22 throttle body, will this work? it has a map sensor that mounts to the firewall I think. I could also get my hans on a B-series throttle body if necessary. What should I go with? I also think the problem is in the TPS sensor because when I unplugged it, the car ran better almost...
Old Feb 24, 2007 | 09:33 PM
smileycvc's Avatar
You dont need a new throttle body. For starters cover up that hole in your throttle body that is most likley causing a vaccum leak. Second check your fast idle valve. To do this:
1. Locate the 2 screws on the back of the throttle body(should be the only 2 there)
2. Completley remove one screw
3. Losen the other screw.
4. Swing the now open plate out of the way.
5. Tightent he disc located inside.
6. Put back together.
Old Feb 24, 2007 | 10:28 PM
nicko360's Avatar
* B A N N E D *
Default Re: (smileycvc)
I can't take it off, its like threaded instead of having a screw, there is just a metal stub sticking out on both sides. Its no problem for me to get another throttle body, hopefully that will solve my problem
javifranks1987
Jul 1, 2014 06:07 PM
Kaneo
Feb 2, 2005 06:23 PM
UNDER PRESSURE
13
Jan 23, 2004 09:48 AM
Malgerus
Aug 8, 2002 11:19 AM
B18C-RnVA
Apr 28, 2002 03:38 PM
