Type R forged intern witch Turbo i need to put!!
B18C5 1999
piston JE 81.5mm 9:1
ring JE pro seal
Rod Eagle H-beam
ARP rod bolt
ARP head stud
OEM crank and new OEMrod bearing
GAsket intake Hondata
head , 3 angle valve
clutch ACT 6 puck
Pressure plate double
LS tranny with Quaife LSD
walbro 255lph gas pump
44mm Tial wastegate
780cc presision injector
fuel rail Eagle +Fuel regulator
i m looking for a GT BB turbo but i want to have fun and with a nice spool its for why i want a GT but witch trim i need to use give me some comment thank you
ring JE pro seal
Rod Eagle H-beam
ARP rod bolt
ARP head stud
clutch ACT 6 puck
44mm Tial wastegate
this one
. jk seriously for street 28rs or the 2871, 2876 im not sure which is most efficient. stay within the t2 esp if you want a gt series turbo, else t3t4 50 trim, somewhere around there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GiNuWiNe »</TD></TR><TR><TD CLASS="quote">I vote GT2871R .82ar</TD></TR></TABLE>
Its rated for ~420hp. For a few hundred $ more, you could get a GT30R with a T3 divided .78ar exhaust housing (atpturbo). It will provide enough power, and spool like crazy.
I have see this graphique and i think its alot what i m looking a GT30/76R ITS ON A B18C5 81.5MM
http://www.synapsemotorsport.c...r.JPG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">
Its rated for ~420hp. For a few hundred $ more, you could get a GT30R with a T3 divided .78ar exhaust housing (atpturbo). It will provide enough power, and spool like crazy.</TD></TR></TABLE>
Does he have a divided inlet manifold also? My vote still goes for the GT2871R .82ar if he doesn't.
Its rated for ~420hp. For a few hundred $ more, you could get a GT30R with a T3 divided .78ar exhaust housing (atpturbo). It will provide enough power, and spool like crazy.</TD></TR></TABLE>Does he have a divided inlet manifold also? My vote still goes for the GT2871R .82ar if he doesn't.
You can't go wrong with the 3076r, it is very responsive, can make your 400whp goal no problem and leaves some room for more down the road. We made that 400 with a conservative tune @ 15psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">GT3076R</TD></TR></TABLE>
349whp @ .7bar spring (10psi)
83mm bore
portflow head
full-race everything else
The initial numbers tell me that 500whp should be no problem on race gas.
GT3076R FTW
83mm bore
portflow head
GT3076R FTW
10psiLsEf2
Nov 12, 2013 02:56 AM
tegman23
Sep 23, 2007 07:54 PM
