HAVING A HUGE AEM EMS PROBLEM!!!!!
Old Feb 24, 2007 | 12:02 PM
EGmmBAH's Avatar
Default HAVING A HUGE AEM EMS PROBLEM!!!!!
Ok here it goes, I have an EMS for a OBD1 integra, with a stock base map in the car reads 40psi with just turning my key to the on position I have tried everything I can think of, if the car does decide to start it will idle for 1 second and turn off I have tried a new map sensor, a new wire harness, hardwiring the map, unplugging sensors one by one untill it stoped reading boost etc, etc, etc, etc. . . if i take the AEM out and plug it into my friends hatch with a stock b-series in it it is fine reads -psi with the key on and with the car running like it shouls and the car drives fine, any ideas???????
Old Feb 24, 2007 | 01:11 PM
Chiovnidca's Avatar
Default Re: HAVING A HUGE AEM EMS PROBLEM!!!!! (EGmmBAH)
Is it possible the map connector is swapped with a different sensor? Which sensor do you unplug to get it to stop reading high?
Old Feb 24, 2007 | 02:22 PM
EGmmBAH's Avatar
Default Re: HAVING A HUGE AEM EMS PROBLEM!!!!! (Chiovnidca)
no it does not stop reading high no matter what i do and map and tps are the only ones with similar plugs and they are correct
Old Feb 24, 2007 | 05:55 PM
Chiovnidca's Avatar
Key on, engine off: What is the voltage on the map signal line at the ecu? Does it match the reading in aempro?
Also is this a new engine install? Sometimes the small ecu ground doesn't get bolted back to the t-stat housing. That can cause alot of odd problems.
Old Feb 25, 2007 | 07:22 PM
EGmmBAH's Avatar
voltage is the same, and it is a rebuild but the block never came out of the engine bay, also the wire harness is brand new and i checked that thanks though. . .
Old Feb 26, 2007 | 03:14 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmmBAH &raquo;</TD></TR><TR><TD CLASS="quote">voltage is the same, </TD></TR></TABLE>
And what is it?
carlos8
36
May 4, 2014 05:42 AM
My_EFsedan
Oct 18, 2011 09:50 PM
kielcivic
Engine Management and Tuning
Jul 21, 2011 06:04 AM
magefa
Apr 8, 2009 06:26 AM
stinker504
May 29, 2007 09:08 AM
