99 civic SI won't start help!!!
hey i have a 99 si and it was running just fine and now it will not start, the check engine code is only for #10 which is due to the aftermarket intake. I can not hear the injectors prime, it has a brand new fuel pump. can anyone help? thanks!
give us a lil more info dude
first check for spark...thats the easiest thing to check....
if you have spark
then check for fuel at the rail...you say you hear the pump prime so most likely you have fuel pressure...
then while the plugs are out do a comp test to make sure you've got compression....with those it should start,,,,,im betting on the coil. . .
if you have spark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">give us a lil more info dude
if you have spark
then while the plugs are out do a comp test to make sure you've got compression....with those it should start,,,,,im betting on the coil. . . </TD></TR></TABLE>
Ichecked and it has spark.
I CAN NOT hear the injectors prime
the car has good compression. ran perfect when i pulled it in the garage to vaccum it and i went to pull it out and now it does not work!
I need a little more details about how to find the main relay you said under the glove box? please give more detail. and what does it look like? sorry like i said i have never had to deal with one before. tomorrow i will try the coil then the relay.
if you have spark
its a brown box, if you look directly up @ the bottom of the glovebox, you should be able to see it, or if you open the glove box, and look to the right, it should be there. i belive it says "relay-main" on it.
on another note... have you checked all your fuses ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhonduh93 »</TD></TR><TR><TD CLASS="quote">could also be bad connection on your injector wiring... im sure youre not running stock ones... id check that too</TD></TR></TABLE>
the injectors are stock the motor is stock.
I have checked all the fuses that would make since nothing is blown. I am going to check the main relay right now and try putting on a different dist. that i know is good.
the main relay is working bc i can hear it click when i turn the key, and i put a distrub that i know is good on it and still not working. I still can not hear the injectors prime. what would cause this?
hotdoggies
15
Feb 10, 2011 04:37 PM
Phil McConkey
Feb 25, 2007 07:42 PM
