Oil In Spark Plug Cylinders
I was pulling out my spark plugs today and cylinder 1 spark plug had a lot of oil around it. Cylinder 2 spark plug had less oil then cylinder 1. Cylinder 3 had less then 2 & 1, but still contained oil. Cylinder 4 had no oil. I removed the spark plugs and realized they were the wrong spark plugs for this car (99 civic HX). Could this be the cause of the oil leak? Or is it a gasket problem? P.S. It has goo around the spark plugs, when I pulled out the spark plug wires off the spark plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vltnolia »</TD></TR><TR><TD CLASS="quote">Cool thanks. While Iam in there Ill go ahead and replace the valve cover gasket</TD></TR></TABLE>
Most of the time the spark plug tube seals come with the valve cover gasket.
screech
Jul 13, 2003 12:44 PM
