Coilover O-Rings (tried searching)
Old Feb 23, 2007 | 02:25 PM
blackrag's Avatar
Default Coilover O-Rings (tried searching)
Ok.. I have no idea where these go..
Ring "C" is metal.
I'm fairly sure rings "B" go inside part "1". Right?
Ok.. I'm lost..
please help me real quick!
Old Feb 23, 2007 | 02:29 PM
JavierP.R.'s Avatar
Default Re: Coilover O-Rings (blackrag)
Ok the o-rings go over the shock absorber body, then you slide the threaded collar(#1) over them, next you sit the springs on the perch and last you put the top hat on(#3).
Good luck!
Old Feb 23, 2007 | 02:31 PM
blackrag's Avatar
Default Re: Coilover O-Rings (JavierP.R.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JavierP.R. &raquo;</TD></TR><TR><TD CLASS="quote">Ok the o-rings go over the shock absorber body, then you slide the threaded collar(#1) over them, next you sit the springs on the perch and last you put the top hat on(#3).
Good luck!</TD></TR></TABLE>
thanks for the quick responce! all the o-rings go on the shock?
Old Feb 23, 2007 | 02:58 PM
MR.johnson's Avatar
nice **** carpet.
Old Feb 23, 2007 | 03:00 PM
blackrag's Avatar
Default Re: Coilover O-Rings (MR.johnson)
thats how we do it
Old Feb 23, 2007 | 03:17 PM
sniggler316's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrag &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the quick responce! all the o-rings go on the shock? </TD></TR></TABLE>
Not all the o-rings. You need two for each shock, one towards the top, one towards the bottom. You have different sizes there. Obviously, you want to use the biggest ones you can and still be able to fit the threaded collar over the shock body.
Old Feb 23, 2007 | 03:42 PM
blackrag's Avatar
Default Re: Coilover O-Rings (sniggler316)
thanks for the help. i just played it by ear.. (ya know what i mean) and it worked out fine.
now work.. then the other three.. blah...
shotgun2224
Suspension & Brakes
17
Dec 19, 2007 10:13 PM
Larkin W.
Mar 20, 2007 02:13 PM
ek_s2k
Honda S2000
10
Jan 24, 2007 08:07 AM
aquabob89
Suspension & Brakes
13
Dec 2, 2005 08:31 PM
DC2tuner
Suspension & Brakes
Nov 22, 2005 01:27 PM
