any one trying use Neukin Turbo Manifold?
hii
im thinking to buy the Top mount manifold from Neukin
http://www.turbogoods.com/inde...ID=40
i`ll buy it with the downpipe and Dumptube but i dont know what thats mean in Extras:
should i choice 2nd O2 and EGT Bung i know the O2 the sensor but what about EGT Bung what thats doing for??
i have a GT35R is it T3 or T4 ???
and the Wastegate should i choice the bigger?? 60mm??
thanks
thanks
everyone of those questions depends on what part you have.
And of course people run Neukin, he makes kick *** manifolds.
you only need an egt bung ig you have an egt sensor to put in there. you dont need a 60mm wastegate. you need to buy your wastegate first before your manifold or at the same time maybe, but youll be fine with the tial 44mm wastegate. do some searching cuz with that kind turbo, its not just something you want to throw onto your honda
if you read the paper work that came with your turbo it will tell you if it's a t3 or t4 frame.
I would say get the second o2 sensor bung you can install a wideband in there without having to remove the stock o2 sensor.
I had a neukin manifold and never had any problems with it. As stated before you should be good with a 44mm wastegate
yea and even if he doesnt decide to put the wideband in there, he can always just plug it up as i suppose its better to have the option rather than not.
as far as manifold quality, neukin makes a very good, life-time warrantied product and i wouldnt hesitate to go with them. just make sure you have all your ducks in a row before you order your manifold cuz it will be a pain in the *** if you get a t3 flange and 38mm wastegate flange and your turbo is actually a t4 and you have a 44mm wastegate. or if you order a ramhorn manifold and have a crx or lunchbox
ok. i do some search and i know the gt35r have T3 frame
but still dont know what wastegate should i choice? how to know the correct size?? what i should know for wastegate?
i read about the O2 sensor so i will keep it with my downpipe for use in the future with wideband
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo »</TD></TR><TR><TD CLASS="quote">you need to buy your wastegate first before your manifold or at the same time maybe, but youll be fine with the tial 44mm wastegate. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">As stated before you should be good with a 44mm wastegate</TD></TR></TABLE>
i want to know why i should coice the 44mm? thats what im asking for i like to know how u know the best for me 44mm?
i want jump to this stage to know what i need. not just to read the aswer without any info!
thanks
thanks
no offense, but it seems you need to do your own research. By the parts your listing it seems that you want to build a pretty killer setup, but had no idea where to start. You have to so some searching your self. Do you have the gt35r already? Because im pretty sure they come in both a t4 and a t3 flange. Your manifold depends on what flange you have on your setup. a 60mm wastegate is a little excessive. A 44mm will be plenty. Go to http://www.evans-tuning.com and read his write up on wastegate sizing. That should help you out.
thanks for the web i`ll read it now
and about the gt35r yes u right they come in both t3 and t4 the t4 with Vband not like t3 4bolt and 5bolt and u can read about it here http://www.gt35r.com/index.html
i have the t3 4bolt frame
DJ Gurgla GSR
Jan 31, 2012 12:01 PM
Reilly
Aug 30, 2005 07:09 PM
DsMWookie
Welding / Fabrication
Oct 21, 2004 03:27 PM
