Honda Approved Fluids
Old Feb 23, 2007 | 02:41 AM
Gustav129's Avatar
Default Honda Approved Fluids
I've notice on forums for other makes, for example there's a list of "VW/Audi" approved oils to use.
Is there such a list for Honda? I did a search and found nothing.
Old Feb 23, 2007 | 05:21 AM
JimBlake's Avatar
Default Re: Honda Approved Fluids (corndog)
I don't remember seeing one all in one place, so maybe this will become the list you're looking for.
A couple vehicles aren't really Hondas, so this doesn't apply. For example the Passport SUV is really an Isuzu.
Too many different engine oils, & different needs over the years. Strong opinions too, so lets not turn this into a flame war...
As far as I know, here's the special needs:
Power steering fluid:
Hondas use their own type, incompatible with others. Genuine stuff from the dealer isn't stupid expensive, so that's a good choice. If you have to go elsewhere, make sure it says "FOR HONDA & ACURA". Don't believe anything that says "all makes & all models".
Automatic transmission fluid:
Genuine stuff is the choice here, too. Although it seems to be compatible with Dexron III, the Honda-brand stuff works better.
Manual transmission fluid:
Honda MTF is good stuff. Before it existed (about 1997) Honda called for 10w-30 engine oil in their manual trannys. Honda MTF is completely compatible for those trannys, arguably better than engine oil.
Brake fluid:
DOT-3 is the requirement, lots of brands are available everywhere.
DOT-4 has higher boiling points but otherwise is fully compatible with DOT-3, so that's also good.
DOT-5 is silicone-based fluid, it's not real easy to find. DON'T USE DOT-5.
DOT-5.1 is poly-glycol based (like DOT-3 & 4) & it's often labeled as DOT-4 (example Valvoline SynPower). It's OK.
After we build this thread into something useful then we can argue to get it stickied at the top of the forum.
Old Feb 23, 2007 | 05:37 AM
Gustav129's Avatar
Default Re: Honda Approved Fluids (JimBlake)
http://forums.vwvortex.com/zer...73105
This is what I found on the VW site, for the Jetta.
This list specifies brands, type, and viscosity.
Just wondering if there was one for Honda.
Old Feb 23, 2007 | 12:13 PM
JimBlake's Avatar
OK, maybe I get it now. VW/Audi has some requirements for their TDI engines that go above & beyond the normal API specs. Saab does something similar with their GM-LL-025 spec. As far as I know, Honda doesn't do that. They're OK with API SM or whatever is the current spec. Apparently Honda didn't invent something more limiting than API.
Old Feb 23, 2007 | 06:57 PM
HondaPartsHero's Avatar
Technical Hero
Don't forget this
Old Feb 23, 2007 | 06:59 PM
kiddcarbuff's Avatar
Default Re: Honda Approved Fluids (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">
Don't forget this </TD></TR></TABLE>
i was waiting for someone to post that. haha
Old Feb 24, 2007 | 05:07 AM
JimBlake's Avatar
Default Re: Honda Approved Fluids (kiddcarbuff)
I heard they were gonna start making VTEC blinker fluid for kids who want their blinkers to go real fast.
dx_rex
Apr 25, 2011 02:54 PM
972drcordex
Jan 10, 2005 04:58 PM
JDM EJ1 95
Jun 3, 2004 08:54 PM
srider
May 30, 2003 03:19 PM
onyx00
Sep 26, 2001 09:23 AM
