Vtec activated at 3.5rpms, Can it hurt anything?
Old May 20, 2002 | 10:18 PM
Magick211's Avatar
Default Vtec activated at 3.5rpms, Can it hurt anything?
Vtec activated at 3.5rpms, Can it hurt anything? Cause i have a rpm activated switch for vtec and right now thats the only pill i have for the switch? and i want to know if its safe to run it that low right now
Old May 20, 2002 | 10:26 PM
SC0TT's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (CivicBoyZC)
I dont think so?! I have my VAFC sometimes set to engage vtec at 3800 on my gsr. The check engine light turns on, but the honda mechanics say it doesnt mean anything bad.
Old May 20, 2002 | 10:31 PM
Magick211's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (cr-tegra)
Oh koo
Old May 20, 2002 | 10:40 PM
manveer's Avatar
I've heard that you're not supposed to activate VTEC lower than 4k because it causes some problems with oil starvation or something.
Old May 20, 2002 | 10:47 PM
HOOKUPS-PRO-CRX's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (manveer)
Activating VTEC at an rpm below 3500 is not a good idea. 1st off you will actually lose low end power and the oil pressure is not high enough to fully lock the rocker arms into vtec position. if you are using an activation box you can change the setiing on the box from 4cyl to 6 cyl and the vtec will activate at 5000rpms, if you have a 3000 rpm pill then it will activate at 4500rpms on the 6cyl setting
Old May 20, 2002 | 11:07 PM
Magick211's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (HOOKUPS-PRO-CRX)
Oh hell yeah, My rpm pill is actually 3.4k, so if i put it at 6cyl what will that be at
[Modified by CivicBoyZC, 8:08 AM 5/21/2002]
Old May 21, 2002 | 03:45 AM
Mista Bone's Avatar
D Tranny Guru
Never heard of a DOHC ZC with VTEC.
Old May 21, 2002 | 04:22 AM
AussieK24's Avatar
Oh you the man!!! I've got the Autometer shift module that came with a crappy 3000 pill and was saving up for the 5000 to 6000 set but I didn't even think of changing the setting to 6 cyl. YOU THE MAN, THANX.
Old May 21, 2002 | 05:11 AM
spettinger's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (Mista Bone)
i hope our friend here didn't pay a shop for a B16 swap. sounds like they may have pulled the old ZC switcheroo. haha
Old May 21, 2002 | 05:34 AM
AussieK24's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (wreckedhatch)
Suppose you can activate VTEC whereever you damn want with a ZC
Old May 21, 2002 | 09:45 AM
CimorelliCRX's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (b16a4me)
what a bunch of dicks, damn. he sold his hatchback about 2 months ago and bought a 90 CRX HF with a D16Z6.
Old May 21, 2002 | 12:04 PM
Magick211's Avatar
First off im talking about a sohc vtec engine
And second of all i think i can tell the differnce between a zc and a b16a ******** to many people here have turned into *********
Old May 21, 2002 | 01:34 PM
Urban Business
Guest
Posts: n/a
im a ******** ask around, its true
Old May 21, 2002 | 02:03 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (CimorelliCRX)
dicks? *********????
atleast I check out his profile hoping he listed a newer combo. Maybe he could change his sig line to reflect the new combo.
If you want help, it helps to list what motor/car your working on.
BTW I'm a *******, get it right!
[Modified by Mista Bone, 6:04 PM 5/21/2002]
Old May 21, 2002 | 02:53 PM
pelotudo's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (TorteX)
TorteX
jB
[Modified by PeloTudo, 6:53 PM 5/21/2002]
Old May 21, 2002 | 03:08 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (PeloTudo)
Yeah you shouldnt have your vtec turn on so soon, you will run out of vtec fluid, and that cost a pretty penny. =x hahha.....^5 *********.
Old May 21, 2002 | 05:41 PM
Urban Business
Guest
Posts: n/a
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (SpoonSportsEF7)
gas milage will be suck-o even if it does activate properly at low rpms
Old May 21, 2002 | 06:50 PM
Well we fixed it today, we got it kicking in at 5000.
Old May 21, 2002 | 08:53 PM
89 CRX SI's Avatar
Honda engineered it to come on at 5400 RPM for a reason. To high and you waste time and hard cam switch over. too low and you dont have oil press and it makes your car bog.
Think of it why wouldnt they just put it lower and have better HP curves
Old May 21, 2002 | 09:20 PM
No More Civic's Avatar
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (89 CRX SI)
Ok, my friend is a certified Honda-Tech at one of the local dealers here, and here's what he told me. Your vtech kicking in that low won't mechanically hurt your engine. It will hurt your low end performance though. The reason they make vtech controllers is mainly for forced induction. Having a lower vtech setting on a turbo or supercharged car will give you more power and a smother power band because the turbo is spooling under vtech.
Old May 21, 2002 | 10:29 PM
Default Re: Vtec activated at 3.5rpms, Can it hurt anything? (SlowCivicDX)
WELL I AM ALSO A HONDA TECH and vtec at too low of an rpm robs the bottom end of oil because there is not enough oil pressure untill above 4000 rpms. the forced induction bit is true. as for the guy that has the 3.4 rpm pill your vtec will activate at 5100rpms. http://www.hookupsimporttek.com
Old May 21, 2002 | 11:17 PM
Magick211's Avatar
Wow my sig isnt updated but does it matter? I asked about vtec kicking in to low it should be the same for any vtec engine that why i didnt say sohc vtec. Im not even gonna argue back anymore
Hey mods could u lock the thread please
HondacivDX
Feb 19, 2012 06:52 PM
tommymoose
Aug 5, 2004 09:37 PM
Civiclaker
Sep 17, 2003 11:05 AM
CLICC916
Sep 20, 2001 11:06 PM
arete213
Sep 10, 2001 08:44 AM
