DX or SI trannys for boost?
Old Feb 22, 2007 | 03:33 PM
MagnaniEG6's Avatar
Default DX or SI trannys for boost?
Ok I'm just wondering if I go turbo would it be best to keep my DX tranny or go with an Si. Motor is SOHC ZC. I was thinking like since the LS tranny is used for boost apps it would be the same with the DX tranny. Would it hurt my performance and 1/4 times?
Old Feb 22, 2007 | 03:39 PM
BlueRex1020's Avatar
Default Re: DX or SI trannys for boost? (MagnaniEG6)
depends on how much psi ur going to run....
Old Feb 22, 2007 | 03:41 PM
MagnaniEG6's Avatar
Default Re: DX or SI trannys for boost? (BlueRex1020)
not sure psi est 200whp-210whp
Old Feb 22, 2007 | 03:45 PM
Ass$nyper's Avatar
Pirate General...YARRRR
ok.... ls isn't good for boost.
Think about why longer gears arn't as good for accel as shorter. I'm not going to start this insane rambling of simple math and how I loathe this urban myth.
use the si tranny.
Old Feb 22, 2007 | 03:46 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagnaniEG6 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I'm just wondering if I go turbo would it be best to keep my DX tranny or go with an Si. Motor is SOHC ZC. I was thinking like since the LS tranny is used for boost apps it would be the same with the DX tranny. Would it hurt my performance and 1/4 times?</TD></TR></TABLE>
Yes it would hurt performance, yes it would hurt 1/4 mile times. The fast man in a race is the one who accelerates quickest, not the one who chugs along to some hypothetical top speed of umpteen billion mph. Also, the only difference in the Si transmission and the DX transmission are the final drives, 4.25 --&gt; 3.88.
Old Feb 22, 2007 | 03:47 PM
MagnaniEG6's Avatar
Default Re: DX or SI trannys for boost? (Max The Amazing)
1) for SI would you recommend the ZC tranny also amzing?
Old Feb 22, 2007 | 03:51 PM
if ur gonna run more than 10psi, in my opinion, i think the dx tranny would be better cus that turbo will have good time to spool up....with the si tranny, da gears might drop a little too quick but if ur not going to boost too high, use the si tranny...just my .02
Old Feb 22, 2007 | 03:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueRex1020 &raquo;</TD></TR><TR><TD CLASS="quote">if ur gonna run more than 10psi, in my opinion, i think the dx tranny would be better cus that turbo will have good time to spool up....with the si tranny, da gears might drop a little too quick but if ur not going to boost too high, use the si tranny...just my .02</TD></TR></TABLE> Do you understand how uneducated that sounds? Good time to spool up = you are taking a long time to accelerate, how does that help?
Read this thread --&gt; The End All Transmission Thread
MagnaniEG6's Avatar
What the Dr said makes sense, good thing is the motor will rev higher then the standerd DX motor or course so Im not really worry about building boost BlueRex. DR will the Si or ZC tranny be better in this app? Thanks for the help guys good info so far
Old Feb 22, 2007 | 03:59 PM
I'm personally going to use the SI transmission for simplicity, but later on I will be using a custom geared transmission with a longer first gear for traction in first. Hell, with my D16Z6 I can break first loose if I'm just cruising along at 10mph.
Old Feb 22, 2007 | 04:00 PM
cool man do wat u gota do...like i said dr....it was jus my "OPINION"......dats it...
Old Feb 22, 2007 | 04:01 PM
MagnaniEG6's Avatar
Default Re: DX or SI trannys for boost? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">I'm personally going to use the SI transmission for simplicity, but later on I will be using a custom geared transmission with a longer first gear for traction in first. Hell, with my D16Z6 I can break first loose if I'm just cruising along at 10mph.</TD></TR></TABLE>
How much lbs you boosting I can even break a sweat at 10mph
Old Feb 23, 2007 | 05:50 AM
Project Y's Avatar
Jesus you guys are rude.
the DX trans is theoretically good to 174 mph. The thing that I would worry about is the strength of the trans. Sacrificing a few tenths for streetability and abundance could be worth it. Shifting every second sucks as well unless you are using your tranny to compensate for lack of power.
Old Feb 23, 2007 | 06:15 AM
G0crxG0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Do you understand how uneducated that sounds? </TD></TR></TABLE>
roflmao, I left this *****, I mean site, because of stuff like that...... I been through a few topics today and their all horrible.... damn I hate people
its simple logic: short gears= fast acceleration.
what the hell do you want a turbo for besides fast acceleration?
Old Feb 23, 2007 | 06:38 AM
Got_soy's Avatar
Default Re: DX or SI trannys for boost? (G0crxG0)
The BS that people think up with transmissions is just stupid. Rock the SI trans, It's fun srsly
Old Feb 23, 2007 | 06:43 AM
fireant's Avatar
Default Re: DX or SI trannys for boost? (Got_soy)
Arent the B-series LS trans and D-series Si trans nearly the same gearing?
Old Feb 23, 2007 | 07:31 AM
Maireeka's Avatar
Default Re: DX or SI trannys for boost? (fireant)
no ls trans has longer gears than the si.
Old Feb 23, 2007 | 07:33 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0crxG0 &raquo;</TD></TR><TR><TD CLASS="quote">
what the hell do you want a turbo for besides fast acceleration? </TD></TR></TABLE>
wtf I heard you were eaten by a stray Jackel and then abused verbally by an oxen group known as the flying parcheesey brothers.
Well nice to see you wonder back HT is kinda sad latly.
Old Feb 23, 2007 | 10:06 AM
G0crxG0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max The Amazing &raquo;</TD></TR><TR><TD CLASS="quote">
wtf I heard you were eaten by a stray Jackel and then abused verbally by an oxen group known as the flying parcheesey brothers.</TD></TR></TABLE>
roflmao, your humor has been missed Max
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max The Amazing &raquo;</TD></TR><TR><TD CLASS="quote">Well nice to see you wonder back HT is kinda sad latly.</TD></TR></TABLE>
My job here is done, I'm officially appreciated by Max.
lol yeah I know HT's been goin to **** for awhile, but I figure I'll give it one more go, plus there are alot of good guys on here like you, Mr.Speaker, Boosted Chemist etc that I dont see on other boards
So hopefully I can help resurrect this **** a bit when I start up my next project
Old Feb 23, 2007 | 10:09 AM
Ass$nyper's Avatar
So hopefully I can help resurrect this **** a bit when I start up my next project</TD></TR></TABLE>
LOL
I gotta sig that.
any details on new project? Funds allowing *saving for a house now* I'm doing a rehaul and making a Brute outta my budget B series.
Stick around and help make it a better place like the HT of yore.
Old Feb 23, 2007 | 10:19 AM
G0crxG0's Avatar
What all is planned for the rehaul? just replacing or upgrading? NA or boost?
My plans: find a new shell, pull my GSR and start building it, swap stuff from new shell to my current CRX so I can either sell it or rock it as a beater. Then I just wanna get all my JDM **** on there (especially the glass roof) and I plan to do alot of write ups for common ?s and what not. IMO the How To's available out there pretty much all suck ***** compared to the quickstop. Otherwise I see a turbo D in my future, but thats a ways away.....
Old Feb 23, 2007 | 10:20 AM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Arent the B-series LS trans and D-series Si trans nearly the same gearing?</TD></TR></TABLE>hydro SI, not cable
Old Feb 23, 2007 | 10:22 AM
Ass$nyper's Avatar
</TD></TR></TABLE>Oh nice! Write ups rock and you know your stuff, hopfully that'll go to the FAQ pronto
I'm not sure... I've talked to some of the all motor guys and I have a wicked cam idea, almost exact same as pro1s but lil more for my exact setup.
Boost is soooo tempting, so no money spending till I know what I want, motor still runs like a dream.
Turbo Ds are great, one of my local buddies has a wicked little t3/t4 setup on a y8 it moves
89dxhunchback
38
Jan 29, 2004 09:23 PM
Crxer
10
Sep 26, 2003 03:41 PM
Toptul_Honda
33
Aug 14, 2003 03:27 PM
egturbo
Jan 17, 2003 01:18 PM
