Clutch install, got some questions...
Old Feb 22, 2007 | 11:02 AM
DFW's Avatar
DFW
Default Clutch install, got some questions...
What all do you need to grease? Does it matter what type of grease? Do you only clean off the clutch and flywheel of oil and grease? And do the torque specs for the flywheel/clutch for the motor or does it go by the clutch you use?
Anything else?
Modified by DFW at 2:26 PM 2/22/2007
Old Feb 22, 2007 | 11:30 AM
SuzukaBlueAP2's Avatar
Default Re: Clutch install, got some questions... (DFW)
Should just need white lithium grease for the throw out bearing.
:edit: If you are installing a clutch, no need to clean it off, per se. But do make sure you don't get the great or oil on the clutch disc, flywheel or pressure plate. It is advisable to handle with gloves or a rag to keep the surfaces clean.
Old Feb 22, 2007 | 11:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote"> And do the torque specs for the flywheel/clutch for the motor or does it go by the clutch you use?
Modified by DFW at 2:26 PM 2/22/2007</TD></TR></TABLE>
Use OE Honda specs for flywheel and pressure plate bolts.
Old Feb 22, 2007 | 12:44 PM
DFW's Avatar
DFW
Default Re: Clutch install, got some questions... (SuzukaBlueAP2)
Thanks
Old Feb 22, 2007 | 01:22 PM
DFW's Avatar
DFW
Do you need to put thread locker on the flywheel bolts or any of the bolts?
Old Feb 22, 2007 | 03:59 PM
vestalfootball72
Guest
Posts: n/a
I always chase the threads and the bolt threads followed by some locktite. The pressure plate bolts sometimes snap the heads off, so just be prepared for that. I think there like 17ft/lbs. check tho
Old Feb 22, 2007 | 04:03 PM
DFW's Avatar
DFW
Default Re: Clutch install, got some questions... (vestalfootball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">I always chase the threads and the bolt threads followed by some locktite. The pressure plate bolts sometimes snap the heads off, so just be prepared for that. I think there like 17ft/lbs. check tho</TD></TR></TABLE>
Ekk. I checked the helms and it said 19ft/lbs, but the lowest setting on my torque wrench is 20ft/lbs...also I dunno what model Integra helms (online pdf) it's for, just says Integra.
Old Feb 22, 2007 | 04:04 PM
vestalfootball72
Guest
Posts: n/a
Ekk. I checked the helms and it said 19ft/lbs, but the lowest setting on my torque wrench is 20ft/lbs...also I dunno what model Integra helms (online pdf) it's for, just says Integra.</TD></TR></TABLE>
You should be fine with 20, I wouldn't worry but thats just me. As for the manual it should be the same as all b series clutches interchange.
nitewolf
Nov 8, 2007 12:03 PM
DFW
Feb 22, 2007 04:05 PM
aZnjCC
Mar 6, 2006 07:09 AM
matht27
Jul 16, 2002 04:34 AM
